trailing arms question
Old Aug 28, 2008 | 07:36 PM
crxnatic's Avatar
Default trailing arms question
is the trailing arms bushing from the 91 integra the same size in diameter and everything the same as the crx trailing arm bushing cause i have 91 integra trailing arms and the bushings for the crx are a lot cheaper than the integra ones so please let me know thanks
Old Aug 28, 2008 | 08:22 PM
GUNMETALREX's Avatar
Default Re: trailing arms question (crxnatic)
Becareful i bought 91 integra trailing arms and the bushing was small then my stock 91 crx bushing i bought energy sus trailing arm bushing for the crx thinking there all the same and that was not the case
all i did was take the spindle asembly off there is the one big nut and 4 or 5 tork(the tork bolts are under the back plate) bolts off the back and swap them over to my crx trailing arm and also use the crx front toe compensator arm on the front of the trailing arm or you will have trouble getting the rear alined
Old Aug 29, 2008 | 05:13 AM
crxnatic's Avatar
Default Re: trailing arms question (GUNMETALREX)
so i will be able to use the crx trailing arms ( drums) just take out the spindle which is basically the whole drum setup and put the integra disc setup on the crx trailing arm?
but anyways the crx trailings arms also need bushing but they will be shipper .. let me know if thats what u did thanks
Old Aug 29, 2008 | 10:10 AM
official-ef8's Avatar
alot of stuff between DA's and EF's are the same. I don't know if you can just swap out the drum assembly for the disc assembly. I did the whole conversion (see thread above titled "crx oem brake upgrade") but mine was from a EF Si. Best thing to do is measure the total length of each trailing arm, and measure distances between bolts. If the measurements are the same, just put the whole DA trailing arm on the car. again, see the post i mentioned for detailed instructions. If you can, reply back and let me know if they are actually the same.
Old Aug 29, 2008 | 04:00 PM
correct do you see the large nut and roek bolts i am talking about take nut off which is a 24mm and the tork bolts are a t47 should work and swap the whole assemblies and then replace the trailing arm bushing. you will also need brake hoses and a 4040 prop valve. are you putting integra brakes up front???
if so get the power booster and brake master cylinder off the integra
get some stainless steet braid brake hose for front and rear less hose expansion and better pedal feel
Old Aug 29, 2008 | 04:13 PM
where in coral springs do you stay i will be down there tomorrow around 3/4 o clock i dont know the area very well but i will be near atlantic and ramblewood hit me up let me know if your still stuck i have problem helping you out if it close to where i going to be
Old Aug 29, 2008 | 08:17 PM
crxnatic's Avatar
ok
Modified by crxnatic at 3:38 PM 8/30/2008
Old Aug 29, 2008 | 09:25 PM
ok i will be down there around 4pm i will login on to the fourm and get directions
or email then to me at r0n420@aol.com
i have a going away party down there i can probly stop by and point out a few things to get you in the right direction......
Old Sep 3, 2008 | 08:16 AM
crxnatic's Avatar
do i really need the 4040 prop valve? im not putting front integra brakes just the rear
Old Sep 3, 2008 | 08:50 AM
yeah even with out integra front brakes you need the 40/40 prop valve with out it you wll be putting more stress on the front brakes and the car wont stop evenly.
You wont get enough brake fluid to the rear
Old Sep 3, 2008 | 03:02 PM
crxnatic's Avatar
where is the 4040 prop valve located usually on the engine bay? i seen it but for the integra whre is exactly located just so i go to the junkyard and remove it off an integra.
Old Sep 3, 2008 | 04:29 PM
it should be on the passanger side front shock tower on both cars
make sure you use a flare nut wrench if not you will round off the fittings.
dano670
Feb 14, 2012 06:31 AM
jacksonww
Oct 5, 2010 05:09 AM
sean burke
Suspension & Brakes
Dec 27, 2009 08:19 AM
redwards
10
Jan 25, 2007 06:35 PM
jeremiah963
Sep 23, 2006 09:12 PM
