wtf!!!! is a.....
ECM....i assume its a fancy word for ECU. well my point is that a mechanic said that my car has a defective ECM and i need a brand new one from the dealership and then it needs to be flushed. i asked where it was at and he said it was kinds under the steering wheel console. so im confused on what the hell he is talking about. so if i could get ur input that would help alot.
Passenger side floorboard underneath the right side of the dash, underneath the carpet. Flushed...? do you mean FLASHED? lol. That's an expensive fix right there. GL
Engine Control Module
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by grandtheftlunchbox »</TD></TR><TR><TD CLASS="quote">Passenger side floorboard underneath the right side of the dash, underneath the carpet. </TD></TR></TABLE>
^^ agreed on location, but what is the car actually doing?? it may not be your ecu so can you list some symptoms that you are havinh??like does your car even start? if so does it not rev past a certain point? is it thwoing any codes? if you dont know what codes im talking about:
https://honda-tech.com/zerothread/1901557
any other symptoms to report?? i just want to make sure you not getting ripped off when it could be somethin as stupid as a sensor
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by longshot »</TD></TR><TR><TD CLASS="quote">seeing how you didnt specify what year, and the mods done to your car are, then theres no telling whats wrong...</TD></TR></TABLE>
Very true
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by longshot »</TD></TR><TR><TD CLASS="quote">...or where its at.</TD></TR></TABLE>
Where what is at? Location of the ECM is not in question, if that is what you're reffering to.
Very true
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMHondaEJ8 »</TD></TR><TR><TD CLASS="quote">ECM....i assume its a fancy word for ECU. well my point is that a mechanic said that my car has a defective ECM and i need a brand new one from the dealership and then it needs to be flushed. i asked where it was at and he said it was kinds under the steering wheel console. so im confused on what the hell he is talking about. so if i could get ur input that would help alot.</TD></TR></TABLE>
More info would help out. What is your car doing? What model and what transmission? Reason I ask is that automatic transmission cars have a TCM (transmission control module) located behind the knee bolster on the drivers side.
ECM/PCM (Engine Control Module/Poweryrain Control Module) is located behind the passengers side kick panel.
compwc18
17
Mar 21, 2005 04:12 PM
