SPEEDO TROUBLE
Old Aug 28, 2008 | 01:44 PM
JOSHGLISSEN's Avatar
Default SPEEDO TROUBLE
I HAVE A 96 GSR WITH A 94 GSR ENGINE. I CAN'T GET MY SPEEDO TO WORK. IT HAS A P0500 CODE. I HAVE CHANGED THE SPEED SENSOR TWICE, THE CONNECTOR, EVEN TOOK CONNECTOR OFF AND DIRECT WIRED IT TO THE SPEED SENSOR. NEED HELP PLEASE!!! ONLY THING I HAVEN'T CHANGED IS THE CLUSTER AND THE ECU.
Old Aug 28, 2008 | 03:03 PM
neardon's Avatar
I'm a Jackass
Default Re: SPEEDO TROUBLE (JOSHGLISSEN)
Have you tried using a VSS off a 96 GSR or just one for the 94?
Old Aug 28, 2008 | 07:15 PM
dchatch's Avatar
check the pins on that female side of the clip, could be the cluster...i had the same problem, put to speed sensors in the car, still didn't work...went out and got a cluster from the junk yard and it worked fine
Old Aug 29, 2008 | 06:59 AM
Default Re: SPEEDO TROUBLE (dchatch)
THANKS, I AM ACTUALLY TRYING TO TRADE SOME PARTS FOR A CLUSTER NOW.
Old Aug 29, 2008 | 07:00 AM
Default Re: SPEEDO TROUBLE (neardon)
JUST THE LONGBLOCK IS A 94 NOT THE TRANNY. I HAVE PUT A BRAND NEW SENSOR IN FOR A 96.
Old Aug 29, 2008 | 10:16 AM
Steven.'s Avatar
I am having the same problem, i changed my cluster it didnt fix it,
i changed the sensor and now it wont work at all not even the old sensor will work
93grayeg
21
Feb 28, 2017 01:33 PM
cualancayotl
Apr 6, 2012 05:35 PM
bboyjimpy
16
Mar 16, 2008 06:28 PM
hip_hop_s0ulchild
Mar 1, 2007 03:41 PM
