Are these craptastic rotars?
I am going to be purchasing brembo front and rear rotars from advance auto. My buddy told me to check these out.
http://cgi.ebay.com/ebaymotors...09013
The brembo's i am buying are 100 for front and rear, and i gotta buy pads. They are also slotted. (or dotted only 1 of them.. i forget) So it's going to be about 200 bucks after it's all said and done. I have a 25% discount cause a friend works for the warehouse. So yeah. Just wanted to know if these are any better or what's up with them. I have been told they work just fine and they aren't a bad purchase but i want to get the tech communities opinion.
Dont know where you live but to my place shipping is 40 bucks, plus 140. Thats only 20 bucks cheaper than what you plan to spend on the brembos. It should be a no brainer to not go with the ebay junk unless u really need that dub.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by neardon »</TD></TR><TR><TD CLASS="quote">Dont know where you live but to my place shipping is 40 bucks, plus 140. Thats only 20 bucks cheaper than what you plan to spend on the brembos. It should be a no brainer to not go with the ebay junk unless u really need that dub.</TD></TR></TABLE>
--- I am not really worried about the money. I was just wondering if they were horrible or not. I was told to buy them from a friend. He said he used them without a problem. So if they really are crap, i will just buy the brembos.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by miamijdmcoupe524 »</TD></TR><TR><TD CLASS="quote">these are not real brembo's FYI. My friend ran these on his DA9 and they cracked in like 2 months. get oem or oem spec made instead.</TD></TR></TABLE>
Reading > You
But yea stick with the brembos, they are one of the best names in brakes. The ebay ones might never give you a problem but you never know what your getting with ebay, or if you will even get it.
Reading > You
Reading > You
But yea stick with the brembos, they are one of the best names in brakes. The ebay ones might never give you a problem but you never know what your getting with ebay, or if you will even get it.</TD></TR></TABLE>
--- I understand. I'll just buy the brembos from advance.
Reading > You
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mfoehrkolb »</TD></TR><TR><TD CLASS="quote">--- I understand. I'll just buy the brembos from advance.</TD></TR></TABLE>
Better yet, get a set of Duralast / Autozone rotors for even less than the Brembos, and skip the slotted and cross-drilled nonsense. You can put the money you save towards good fluid and pads.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Padawan »</TD></TR><TR><TD CLASS="quote">
Better yet, get a set of Duralast / Autozone rotors for even less than the Brembos, and skip the slotted and cross-drilled nonsense. You can put the money you save towards good fluid and pads. </TD></TR></TABLE>
this is the best idea so far. Do you know if they still have that lifetime warranty?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrdeadman »</TD></TR><TR><TD CLASS="quote">Do you know if they still have that lifetime warranty? </TD></TR></TABLE>
They actually cut it back to 2 years for the Duralast and 1 year for the Valuecraft.
They actually cut it back to 2 years for the Duralast and 1 year for the Valuecraft. </TD></TR></TABLE>
really? i just put new duralast brakes and rotors on the bonneville from autozone 2 months ago, straight swap deal.
--- Why nonsense? I honestly don't think it does anything, but people swear by it.
--- Why nonsense? I honestly don't think it does anything, but people swear by it.</TD></TR></TABLE>
Less surface area for brake pad contact.
Less metal for heat dissipation.
Less structurally sound (meaning higher chance of cracking or breaking)
More rapid pad wear.
And all of this, to combat an issue with brake pads that hasn't existed since the 60s. Brake pads no longer "gas out" during use.
It looks damn cool though.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TunerN00b »</TD></TR><TR><TD CLASS="quote">
It looks damn cool though.</TD></TR></TABLE>
--- So higher end cars just have them for looks? I guess i will be ordering some cheapo duralast brand.
I have baer slotted and drilled rotors standard size with hawk pads, I have also switched to dot5, (which was a ***** and cost a little more then I wanted but worked for the best, my DA stops 10x better then alot of cars out there with this set-up and I am very pleased with it
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mfoehrkolb »</TD></TR><TR><TD CLASS="quote">--- So higher end cars just have them for looks?</TD></TR></TABLE>
In most cases, yes.
In most cases, yes.
kysard
13
Dec 30, 2004 03:58 PM
hondacivic4g
Jan 8, 2002 11:20 PM
