Masking tape wont come off
Old Aug 28, 2008 | 07:35 AM
qazaq's Avatar
Default Masking tape wont come off
i taped corners of my new carbon fiber hood not to scratch it during installation, but now it doesn't come off. only the top layer peels off and other half and glue stays on the hood
corners were taped with scotch #2090 blue and wide stripe of scotch #2020 white, blue came right off
any suggestions how to get it off without damaging the hood?
Old Aug 28, 2008 | 10:48 AM
ReDemoN's Avatar
DixielandImports Please
Default Re: Masking tape wont come off (qazaq)
Get some kind of residue remover and a razor balde and go to work.
Just be careful not to scratch the hood.
It looks like the tape got wet.
That tape doesnt like water very much.
Old Aug 28, 2008 | 10:59 AM
qazaq's Avatar
Default Re: Masking tape wont come off (ReDemoN)
i figured so :/
Old Aug 28, 2008 | 11:08 AM
pure_integra_45's Avatar
solvents or laquer thinner or what also works is dish soap
Old Aug 28, 2008 | 11:51 AM
MJOLNIRvTEC's Avatar
Default Re: (pure_integra_45)
hit it up with a hair dryer too before you apply all the gun and stuff, itll help
Old Aug 28, 2008 | 01:35 PM
PhantoM.DA's Avatar
GDD GRAMMAR POLICE
Use goo gone. I've gotten stickier **** than that off with it.
Old Aug 28, 2008 | 02:09 PM
qazaq's Avatar
Default Re: Masking tape wont come off (PhantoM.DA)
tried goo gone, didn't work so good.
i got it off with pain thinner then washing with soap n water. also let engine run for a little to heat it up
Old Aug 28, 2008 | 02:25 PM
DatDBisNaSty's Avatar
I dono if It will mess up the carbon fiber or not..
Try easy off fume free oven cleaner..
Laugh at me but its the best cleaner i used ever!!
Old Aug 28, 2008 | 03:21 PM
Eyger's Avatar
I wouldn't put anything on it! I don't know about you but I wouldn't trust any chemicals on the carbon fiber hood. I would use a razor and gently scrape it off. That's what I would do.
Old Aug 28, 2008 | 06:05 PM
DynastyRacer22's Avatar
get as much as u can off with ur finger nails and the rest try using goo gone to get the sticky stuff off..paint thinner might make ur clearcoat look dull
Old Aug 29, 2008 | 04:22 PM
"paint thinner might make ur clearcoat look dull " false
clear coat is a catlist once activated and dry it isnt effected by solvents with the exeption of paint striper
the reason why the finish is dulled is because it removes the wax and polish .
btw oven cleaner is a BAD BAD IDEA
Old Aug 29, 2008 | 04:24 PM
the lesson here to learn is not to buy cheap tape and leave it on the car in :
*hot sun
*wet conditions like wet sanding(colorsanding)
* or long periods of time
Old Aug 29, 2008 | 05:09 PM
qazaq's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pure_integra_45 &raquo;</TD></TR><TR><TD CLASS="quote">the lesson here to learn is not to buy cheap tape and leave it on the car in :
*hot sun
* or long periods of time </TD></TR></TABLE>
im not that experienced with tape, i used what i had. and u never know unless you try
Old Sep 5, 2008 | 10:37 AM
well sorry said "might" and thats a good fact to know that it only looks dull because its removing the polish and wax
Old Sep 5, 2008 | 11:54 AM
-NA-aLL-thE-wAy-'s Avatar
EFSS153
Default Re: (Eyger)
WD-40!!!
I would NOT use a razor blade as some have suggested.
grape1161
Jun 1, 2009 07:29 PM
qazaq
Aug 29, 2008 05:08 AM
oddmut
Paint and Body
Sep 12, 2007 04:41 AM
BSIXTEENSOFAST
May 18, 2007 07:47 PM
cloproductions
10
Sep 5, 2005 10:20 AM
