lca, camber kit
Old Aug 28, 2008 | 07:30 AM
93dagsr's Avatar
Default lca, camber kit
i just swapped out my rear drums for some 97 integra gsr disc brakes on my 95 civic ex. my question is what do i buy my lca's for? and what do i buy my camber kit for? thanks!
Modified by 93dagsr at 1:12 PM 8/28/2008
Old Aug 28, 2008 | 07:49 AM
23-10's Avatar
Default Re: lca, camber kit (93dagsr)
The LCAs are for looks (if its aftermarket) and to add a rear sway bar. (stock ones to add a sway bar)
A camber kit would be to have a higher or lower camber rate on your alignment.
Old Aug 28, 2008 | 08:15 AM
Unit44justin's Avatar
I think he means what car would he buy LCAs and a camber kit for, not what their function is.
Old Aug 28, 2008 | 08:40 AM
luder916's Avatar
dont know about LCA's but camber kits should be for civic. They should fit integra's also. I done this swap but didnt get LCA's.
Old Aug 28, 2008 | 11:10 AM
93dagsr's Avatar
so... stock lca's? i knew what they were for i know that they're mainly for looks. i just wanted to know what to ordr them for???
thanks a camber kit for the 95 civic will fit then?
oops meant to put that the car is a 95 civic ex
Old Aug 28, 2008 | 05:06 PM
geebs's Avatar
Default Re: (93dagsr)
get lca's and camber kit for your 95 civic ex. all you swapped, or was supposed to swap, was the trailing arm and brake setup.
Old Aug 28, 2008 | 05:32 PM
Bob Dole!'s Avatar
Default Re: (geebs)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by geebs &raquo;</TD></TR><TR><TD CLASS="quote">get lca's and camber kit for your 95 civic ex.</TD></TR></TABLE>
Old Aug 28, 2008 | 05:40 PM
Hanmin's Avatar
civic.... integra.... lca's are close enough, if not they are the same, buy either one. The stock integra allows bolts for a sway bar or whatever its called. Camber kit is the same too i think, But I would get the integra one just to be on the safe side. Rear camber can be adjusted with washers=] if you wanna save money. You also need longer bolts as well.
Old Aug 29, 2008 | 07:52 AM
93dagsr's Avatar
thanks guys!
dragon909boi
Honda Civic (2006 - 2015)
Apr 10, 2016 04:05 PM
P@@RB@Y
Dec 22, 2005 09:38 PM
Manofsnow
16
Nov 17, 2004 07:42 PM
tolowhb
Feb 22, 2003 12:57 PM
deez nuts
14
Feb 3, 2003 11:16 AM
