H22a 105k miles...Vibrates at all speeds during accel...what could it be?
Old Aug 28, 2008 | 05:44 AM
prelude97autodamn's Avatar
Default H22a 105k miles...Vibrates at all speeds during accel...what could it be?
hi.
i have a 97 prelude h22a with 105k.
recently it has started vibrating during accel....at all speeds.
what could it be?
thank you
Old Aug 28, 2008 | 06:45 AM
MJOLNIRvTEC's Avatar
Default Re: H22a 105k miles...Vibrates at all speeds during accel...what could it be? (prelude97autodamn)
alignment, loose lugnut, unbalanced wear on your tires, fcked up shock, or some other suspension piece worn out
Old Aug 28, 2008 | 07:05 AM
97ludedude's Avatar
Default Re: H22a 105k miles...Vibrates at all speeds during accel...what could it be? (MJOLNIRvTEC)
how bad is the vibration? does it vary with vehicle speed? does it have the vibration when you are sitting still? agree probably in the suspension. umm. . . . when is the last time it had a timing belt/balance shaft belt. if the balance shaft belt broke you may be picking up the slight vibration from the engine. if that is the case it will have a vibration while sitting still also. (engine running of course)
Old Aug 28, 2008 | 11:51 AM
pprowler6's Avatar
Default Re: H22a 105k miles...Vibrates at all speeds during accel...what could it be? (97ludedude)
worn out cv boot on your axle(s). wheel bearing(s), engine mount(s)
Old Aug 28, 2008 | 01:24 PM
preludepower01's Avatar
Default Re: H22a 105k miles...Vibrates at all speeds during accel...what could it be? (pprowler6)
motor mounts
Old Aug 28, 2008 | 01:36 PM
Scheizty's Avatar
^^^ sounds like motor mounts if it only occurs during accel/decel.
Old Aug 28, 2008 | 02:10 PM
Kronn 98SH's Avatar
Default Re: H22a 105k miles...Vibrates at all speeds during accel...what could it be? (Scheizty)
wouldn't a bad motor mount cause vibrations while stationary and revving engine? If so, should be a simple test.
Old Sep 7, 2008 | 03:35 PM
h22blake's Avatar
Default Re: H22a 105k miles...Vibrates at all speeds during accel...what could it be? (preludepower01)
prolly a worn cv boot. does it also pop when you take turns
Old Sep 7, 2008 | 06:30 PM
Cosa Nostra's Avatar
Default Re: H22a 105k miles...Vibrates at all speeds during accel...what could it be? (h22blake)
Last time i broke an axle it did exactly what you are describing. It will probably continue to get worse so i'd get it checked out asap
Old Sep 7, 2008 | 06:57 PM
vinuneuro's Avatar
If it's only during acceleration it's most likely a bad axle.
Old Sep 21, 2008 | 06:38 AM
Default Re: H22a 105k miles...Vibrates at all speeds during accel...what could it be? (vinuneuro)
correct, it is only vibrating when i accel. and it is in gear and moving, not while it is in park.
also, it seems to get significantly worse when going uphill.
personally, i think it sounds like something with the driveshaft or cv boot.
any suggestions?
PreludeBC420
Aug 23, 2016 03:00 PM
civichorton
28
May 15, 2010 07:45 PM
G2IntegraGS
May 10, 2009 05:26 PM
hankd
Oct 14, 2004 01:13 PM
se93
Jan 25, 2003 08:44 AM
