Temperature switch stuck!
Old Aug 27, 2008 | 09:08 PM
SuperNubb's Avatar
Default Temperature switch stuck!
Hey guys! I've been the proud owner of a 94 GSR for a little bit over a month now, and I'm still a little clueless about certains aspects of my car, so please bear with my noobyness. And yes, I did search, but the results I recieved were a little vague and hard to interpret for a car novice.
Ever since I bought the car, the temperature switch has been stuck all the way to the right (hot). In my attempts to free the switch, the actual **** became detached from the whole lever, so its basically just sliding back and forth freely along the track. I was successful in being able to move the lever to almost the middle by sticking a small metal rod inside and trying to force it to move, where it now lies promptly stuck. I left it like this for awhile because my AC wasn't working due to not having an AC belt installed, but I recently got around to installing one, so now its gonna actually start to matter.
So I was wondering if there was any way to easily make it unstuck, and if there was any way I could reattach the **** back onto the lever? Thanks in advanced!
Old Aug 28, 2008 | 12:59 AM
dohczccrx's Avatar
Default Re: Temperature switch stuck! (SuperNubb)
just get a new unit from the junk yard man and save yourself all the headache
Old Aug 28, 2008 | 05:27 AM
Sweetsystem's Avatar
Sounds like the Heater Core coolant Valve is stuck.
In your engine bay underneath the intake manifold along the fire wall you will find the heater hose that attaches to the valve. This valve allows hot coolant to flow into your heater core and get your cabin warm when the blower motor is on. Your valve is probably stuck or the wires that control it may be jammed. I dont think your in cabin control panel is broken, unless you broke it trying to force it to the other side.
Old Aug 28, 2008 | 06:27 AM
AWD Terror's Avatar
Default Re: Temperature switch stuck! (Sweetsystem)
Most of these cars do that. I took the cable off my control unit and let it sit in WD40 over night. It's still a little tough to move, but I can live with it.
Another good idea is to quit acting like a four year old and grow some muscle.
chad
Mar 27, 2009 06:59 PM
cats_on_ice
Jul 15, 2006 05:36 AM
SOHC_MShue
Aug 19, 2004 08:37 PM
blaisepascal
Aug 5, 2004 07:25 PM
io_burn
14
Feb 25, 2002 05:07 PM
