First year for rear disc brakes on CRX Si???
Old Jul 24, 2002 | 06:02 AM
Soichiro Jr.'s Avatar
Default First year for rear disc brakes on CRX Si???
My mom has an '89 CRX Si, and it doesn't have rear discs. Was '90 the first year? Thanks. PEACE OUT!
Old Jul 24, 2002 | 06:12 AM
ricodemus's Avatar
Default Re: First year for rear disc brakes on CRX Si??? (Soichiro Jr.)
yes.
Old Jul 24, 2002 | 06:38 AM
spiceisler's Avatar
Default Re: First year for rear disc brakes on CRX Si??? (ricodemus)
I don't think it was '90 it was '91.
Old Jul 24, 2002 | 06:44 AM
ivanED9's Avatar
Default Re: First year for rear disc brakes on CRX Si??? (clean90Si)
'90 Si I believe...
Old Jul 24, 2002 | 06:50 AM
ricodemus's Avatar
I'm almost positive the 90-91 crx si was the only 4th gen crx/civic with rear discs (unless the EX sedan had them).
Old Jul 24, 2002 | 06:55 AM
b16powwer's Avatar
i have a 90 and a 91 crx si's, they both got 4 wheel disk brakes, these 2 years where the only ones w/4 wheel disk brakes.
Old Jul 24, 2002 | 06:58 AM
spettinger's Avatar
correct. 90-91 crx si have 4 wheel disc. however, i have yet to see a 4 wheel disc sedan. i have heard that for larger rotor upgrades on the front it is necessary to have the EX sedan front hubs, but i have not seen any yet.
Old Jul 25, 2002 | 04:57 AM
Default Re: First year for rear disc brakes on CRX Si??? (wreckedhatch)
Thanks for the replies. I imagine it's fairly easy to convert an '89 to the '90's rear disc set-up, right? Can someone please list all the parts I'd need to snag off a junked '90 CRX to do this. Thanks. PEACE OUT!
Old Jul 25, 2002 | 05:13 AM
spiceisler's Avatar
If the swap is from CRX to CRX you will need the complete rear arms with spindles, caliper, rotors, e-brake cables. If its for the hatch the CRX e-brake cables won't work. You will have to get the cables from the 90-93 teg. The complete rear arm assembly from those Integras will also work. I have 92 Teg's on my hatch.
Old Jul 26, 2002 | 10:41 AM
Thanks for the replies again. I want to buy better rims for my moms car, but we can't have those rear drums peeking through the rims, now can we?lol. Looks like I need to do the rear disc conversion first. Thanks again. PEACE OUT!
Old Jul 26, 2002 | 02:27 PM
simike's Avatar
Is it worth the effort and time for this swap, or should i just keep my drums?
Old Jul 26, 2002 | 03:07 PM
Denny317's Avatar
Default Re: First year for rear disc brakes on CRX Si??? (simike)
It depends on how much power your car is making. If a lot, you definitely might consider upgrading your braking system, if not, then I wouldn't worry about it too much as the drums will be enough.
iheartmyh0nda
18
Jun 18, 2007 08:16 AM
crxhftosi
Jan 30, 2005 10:13 PM
APEX CRX
Jun 3, 2003 10:11 AM
Jamison182
Apr 7, 2003 07:11 PM
nichols
10
Feb 14, 2003 07:53 PM
