FS Alpine SEC 100S NEW ALARM
FS Alpine SEC 100S new, never installed. I sold my car before I installed this. Great alarm!
Don't get your car stolen!!!
Convenience Features:
* 3 EXT Outputs
* Alarm Silencing Through Remote Control
* Armed Output
* Audio Control Output Capability
* Car Finder Function
* Digital Pager Data Output
* Dome Light Surveillance Output
* EXT Trunk Sensor Cancel
* Faulty Sensor Bypass
* Lock/Unlock Outputs
* On-Board Light Flash Relay
* Priority Door Unlock Output
* Programmable EXT Outputs (Pulsed, Continuous, Latched)
* Remote Starter Compensation
* SEC-8205 Digital Pager Data Output
* SEC-8348 Infrared Audio Controller Output
* Sensor Cancel
* Silent Arm (Capable)
* Tripped Sensor Indication
* Tripped Sensor Warning
* Two Car Operation
Remote Control Features:
* 4-Button remote Control (SEC-RC001)
* 5,300 Trillion cubed possible code combinations
* Full Time Panic
* Impact Sensor Adjustment
* Keyless Entry In Valet
* Protected Valet
* Silent Arm (Selectable)
* Surface Acoustic Wave (SAW) Technology
* Two Remote Controls Included
Security Features :
* 115dB soft Chirp Siren
* 123dB Soft Chirp Siren
* Code Learning (Up to Four Independant Remote Controls)
* Door Trigger Input
* Dual Stage Impact Sensor Included
* Hood/Trunk Trigger Input
* Ignition Trigger Input
* LED Status Indicator
* Microprocessor Controlled Main Unit
* Panic Re-Arm (Selectable)
* Selectable Ignition Controlled Door & Unlock
* Selectable Starter Interrupt (NO/NC)
* Starter Interrupt Relay Included
* Super Bright Crystal Blue Status LED
* Super Regenerative Receiver
* Superheterodyne Receiver with SAW Technology
* Superregenerative Receiver
* Valet/Disarm Switch
Specifications:
Remote Control Specs:
* Battery : 12V Alkaline (MN21/GP23A/VR22)
* Battery Life : 1 Year (Typical)
* Dimensions (W x H x D) : 2-1/3” x 1-1/2” x 1/2”
* Model Number : SEC-RC001
* Remote Control Range : 100ft (Typical)
* Transmitter Type : Radio Frequency
* Weight : 20g (0.7 oz)
Security System Main Unit Specs:
* Armed Output (Negative) : 200mA
* Dimensions (WxHxD) : 4-3/4” x 3-1/3” x 1-1/4”
* Dome Light Surveillance Output (Negative) : 0.2A
* Door Lock/Unlock (Selectable) : 0.2A
* EXT 1 Output (1Second or Latched [Negative]) : 0.2A
* EXT 2 Output (1Second or Latched [Negative]) : 0.2A
* EXT 3 Output (Continuous or1Second [Negative]) : 0.2A
* Idle Current (Armed) : 18mA (with LED)
* Idle Current (Disarmed) : 16mA
* LED Output (3V Positive) : 10mA (constant)
* Main Unit Weight : 150g (5.3oz)
* Operating Temperature : -30° to 60° C (-22° to 140° F)
* Operating Voltage : 12V DC (10—16V allowable/negative ground)
* Pager Output (Digital) : 200mA
* Parking Light Output (Positive) : 10A Fuse Max
* Priority Door Unlock Output (Selectable) : 0.2A
* Siren Output (Positive) : 2A
* Siren Sound Pressure Level : 114dB at 12VDC 30cm
* Starter Interrupt (Negative) : 0.2A
$65 shipped OBO
Modified by em96civicex at 11:13 AM 9/1/2008
* 3 EXT Outputs
* Armed Output
* Sensor Cancel
* Two Car Operation
* Full Time Panic
* Protected Valet
Security Features :
Specifications:
$65 shipped OBO
Yes, they are included. Just so you know, it is a copy of the original instructions that I printed out from the Alpine website because I don't have the original one. It is the same though. I'll link it later when I get home from work.
