Intake Manifold
Old Aug 27, 2008 | 11:45 AM
Horseofcourse's Avatar
Default Intake Manifold
I am rebuilding my GSR right now with 10.5 comp and omnipower valves that supposedly raise compression. 81.25 bore and Crane Stage 1 cams. Should i keep the GSR intake manifold or ditch for a single stage aftermarket one such as Blox/skunk2/Edelbrock. And if so what do you guys think i should get for this set up also your recommendations for throttlebodies
Old Aug 27, 2008 | 01:00 PM
Rocket's Avatar
Default Re: Intake Manifold (Horseofcourse)
Depends on what you have in mind for tuning. If you are going to stick with stock P72 ecu then don't stray from the OE GSR IM.
Fo-shizzay!!
Old Aug 28, 2008 | 01:41 PM
No im going to get a socketed ecu or a hondata setup and have it tuned.
Old Aug 28, 2008 | 01:54 PM
Rocket's Avatar
Default Re: (Horseofcourse)
Perfomer X + Omni TB would be nice. This IM is geared for more mid which is consistent with your cam choice.
Old Aug 28, 2008 | 02:02 PM
What size TB would you recommend. And are the hondata gaskets a good choice? And do you think i should get the omni High Comp valves or normal
Old Aug 28, 2008 | 02:21 PM
Rocket's Avatar
1. 68mm is works well.
2. Hondata or other heatsheild gasket works good. Reccomended by a tuner buddy of mine.
3. Supertech or Omni is good for vavles.
Old Aug 28, 2008 | 02:23 PM
b20sedan's Avatar
B20 Bhai M.B.B.S
Default Re: (Master of the Universe)
I’m running a Performer X IM and a Professional Products 68mm TB. Can’t beat that throttle body for the money.
Old Aug 28, 2008 | 02:27 PM
i was asking should I get omni's High Compression valves that raise compression. Or just go with there standard valves
Old Aug 28, 2008 | 02:29 PM
Rocket's Avatar
Hi comp is good. Every bit helps. Also this is a very popular valve choice so re-sale value of the head would be more than if you had dished valves.
Old Aug 28, 2008 | 02:46 PM
Master of the Universe For The Win
Old Aug 28, 2008 | 04:04 PM
Rocket's Avatar
Big Upps!!!!
Fo-shizzay!!!
Old Aug 28, 2008 | 08:41 PM
Aquafina's Avatar
Very happy with the Performer-X. Though I think the 60mm is a bit much for the low-mid.
Old Aug 28, 2008 | 11:37 PM
Thanks for the help. One last question tho.
How do you guys rate the Blox and Skunk2 manifolds? or other brands i havnt considered yet. It seems the Edelbrock is the more expensive than some. And Aquafina did you mean the 68mm is to big? What size do you recommend. Im trying to get the most performance while still keeping it streetable.
Old Aug 28, 2008 | 11:59 PM
Aquafina's Avatar
Quality alone Edelbrock is the best.
60mm is too big for my setup (low-mid range was hurt, topend gained). I have a D16 though.
Old Aug 29, 2008 | 01:09 AM
Fat Chick Magnet's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Horseofcourse &raquo;</TD></TR><TR><TD CLASS="quote">
How do you guys rate the Blox and Skunk2 manifolds? </TD></TR></TABLE>
I just rate the skunk2 manifold to be good because It's C.A.R.B. legal and here in California cops are lame.
Old Aug 29, 2008 | 09:03 AM
Well i live in oregon No Smog Boyzzz. No emission problems. No modification problems. Just loud exhaust is all they will nab you for. this car im going to run a tanabe or if i can find a good used RSR setup
Old Aug 29, 2008 | 10:43 AM
clem kevin's Avatar
you guys using the performer x, are you using it on the track or just as a daily driver? building a road race motor(gsr) and am torn between the aebs and the performer x, simply based on some of the info that the aebs is designed to line up with gsr ports better, but the performer x is a higher quality. ill be using CTR cams
Old Aug 29, 2008 | 10:57 AM
b20sedan's Avatar
B20 Bhai M.B.B.S
Default Re: (clem kevin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by clem kevin &raquo;</TD></TR><TR><TD CLASS="quote">you guys using the performer x, are you using it on the track or just as a daily driver? building a road race motor(gsr) and am torn between the aebs and the performer x, simply based on some of the info that the aebs is designed to line up with gsr ports better, but the performer x is a higher quality. ill be using CTR cams</TD></TR></TABLE>
I have the Performer X and I built my car with the intention to autocross, time attack, etc. (Since getting married, I haven’t actually done it though… ), it gave my motor an appreciable increase in power in the mid-range as well as at higher revs. No complaints from me.
Old Aug 29, 2008 | 11:05 AM
Thanks for everyones help.
xialbyix
Dec 6, 2007 06:19 PM
DVC2008
Dec 26, 2004 09:26 AM
Supahr_Ed
Nov 2, 2004 10:31 PM
Mikex25
Nov 5, 2001 08:14 AM
