MAIN RELAY HELP!!!
Old Aug 27, 2008 | 09:44 AM
rolledthatho's Avatar
Default MAIN RELAY HELP!!!
hey guys, im pretty familar with faulty main relays, they lose their solder connections.i have actually soldered a few of the pins on this one before, but now i get in the car, cold or hot, (a lot of times it just wont work when hot) and it will turn over a time or 2 then after that when i turn the ignition i get this low funny inconsistant buzzish noise coming from the main relay.
i pulled it out and none of the solders have cracked pins or anything, and when i turn the key the engine light comes on, but goes off like its supposed to???\
if there is no fix for this, where is the cheapest place to get a main relay? and what cars can i pull it from/interchangeable
ps i thought i rem hearing about a place online that sells refurbished ones for cheap
any help is appreciated
Old Aug 27, 2008 | 10:34 AM
91whiteREX's Avatar
Default Re: MAIN RELAY HELP!!! (rolledthatho)
i have a relay for 30 bux free shipping
Old Aug 27, 2008 | 10:49 AM
Ermil's Avatar
Default Re: MAIN RELAY HELP!!! (91whiteREX)
I don't understand how someone can be so broke that they look for a used or refurbished relay. I have a brand new OEM one I got for $40. I'd rather have a new one than a potential headache.
Just install a new one.
Old Aug 27, 2008 | 10:51 AM
91whiteREX's Avatar
Default Re: MAIN RELAY HELP!!! (Ermil)
Mine is a new honda unit, was in a car for maybe 2 months before the crash.
Old Aug 27, 2008 | 01:08 PM
zccrx's Avatar
check your grounds and check the fuses in the engine bay. i had this same problem after multiple oem relays and it turned out to be a fuse under my hood or it could have been a ground, i did both with out turning the car on so i could not pin point the problem, but one or the other worked for me.
Old Aug 27, 2008 | 02:24 PM
thats right you dont understand. so dont make assumptions. and congratulations of the dumbest comment of the week award. i didnt ask which would be better i asked for peoples help. half the **** you buy and think is new, IS refurbished. why do you think you turn in cores on starters, alternators etc...
do what you do
also thanks for everyone elses help. its appreciated, zccrx which relay under the hood was it?
Old Aug 27, 2008 | 03:36 PM
beige89civic's Avatar
* B A N N E D *
I agree. I bought a new Honda main relay for the same price. I don't screw around with attempting to fix burnt up electrical parts. If you really want cheap, go to a junk yard and jack one.
Old Aug 27, 2008 | 08:33 PM
reynardmauricio's Avatar
Default Re: MAIN RELAY HELP!!! (beige89civic)
u can jump the 2 "outputs" (yellow wires with black stripes) on the main relay to igniton power input (black wire with yellow stripe) on the main relay and see if that runs the car after u crank it and all. all this does is bypass the relays in the main relay and u manually send power to the things the main relay powers up (fuel pump and injectors basically)...
Default Re: MAIN RELAY HELP!!! (reynardmauricio)
if that doesn't work ^^^^, it's something else...
Old Aug 28, 2008 | 12:24 PM
slicedbreadno2's Avatar
can't you just re sodder the preexisting one.
sd619jef9
17
Feb 5, 2017 08:20 AM
tk_S2K
Feb 6, 2009 04:59 AM
Mr.Speed
Dec 19, 2008 01:07 PM
ninjarich2
May 11, 2007 12:51 AM
91d15bvtec
Jun 27, 2005 06:15 PM
