Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
negative camber
Old Jul 24, 2002 | 04:50 AM
ZUL8R's Avatar
Default negative camber
how far neg in the front should i go on a FWD car, and still have decent wear on the street. the reason is i want it to handle alittle better for auto cross, and i was chunking the outside of my tires last event.
Old Jul 24, 2002 | 04:54 AM
Willard's Avatar
Default Re: negative camber (shane Z)
try -1.0.... then -1.5 see what works better with your setup.
Will
-who only has -0.7 on his front wheels.
Rodney's Avatar
I forgot more about hondas then you will ever know....
From: hop,skip, and a jump from the city,, new friggin york, USA
i run -3 degrees on my fwd autocross/street car. i tear through tires anyway, so it didn't matter to me. how long do you want them to last?
Old Jul 24, 2002 | 05:38 AM
Doctor CorteZ's Avatar
93 civic hatch on Azenis
camber front - 1.6 rear - 1.2
toe (which wears tires more than camber) front 1/16" out on EACH side
rear - 0
I have completely perfect wear on my 3 sets of tires I've been thru with this setting
which includes a few 1000 mile trips
4 track days
backroad jaunts daily
my car is very nice with these settings and doesnt eat tires bad at all
Old Jul 24, 2002 | 10:36 AM
maxQ's Avatar
Depends. Macpherson strut, double wishbone, leaf spring()?
You don't need as much static camber in a double wishbone setup as you would for a MacPherson strut, for example.
I ran -2 degrees in the front with my Macpherson struts and had minimal wear.
Old Jul 24, 2002 | 12:42 PM
Mojo-Jojo's Avatar
Default Re: negative camber (maxQ)
Try some caster.
http://www.whiteline.com.au/articles/RH_Civic95a.htm
That way, when the tires are straight, the bottoms are flat. When you turn, the tires lean in a bit. And, instead of just the outside tire ending up flat like with negative camber, BOTH tires lean into the turn, instead of the inside tire leaning WAY out of the turn.
[edit]
another good article:
http://www.advancedracing.com/grmart1.html
[Modified by Mojo-Jojo, 2:31 PM 7/24/2002]
Old Jul 30, 2002 | 04:59 PM
rex_boy's Avatar
Default Re: negative camber (Mojo-Jojo)
Are the (Top Right) and (Top Left) wrong in these pictures. The descriptions seem right?
[Modified by rex_boy, 4:00 AM 7/31/2002]
Old Jul 30, 2002 | 09:56 PM
.RJ's Avatar
.RJ
Default Re: negative camber (rex_boy)
-2 degrees and about 1/8" total toe out in front. No tire issues, just even wear. Macpherson struts...
And i *know* Andy hates my 225/45's all the way around and lots of yummy camber...
Fo-Do Fanatic
Jan 2, 2010 04:26 AM
jordancrockett
Dec 7, 2008 12:54 AM
sirEGhatch
Suspension & Brakes
Nov 5, 2008 05:48 AM
jnuanz382
May 4, 2007 10:11 PM
