ls/vtec handling stress?9,500rpm?told it could safely...
Old Aug 27, 2008 | 08:34 AM
671XxDaRkCyDexX's Avatar
Default ls/vtec handling stress?9,500rpm?told it could safely...
parts...
ctr pistons
acl rods&main bearing
arp connecting rod bolts
arp head studs
gsr ported&polish head
blox block guard
crower stage 2 cams(n/a)
skunk 2 pro cam gears
2.5 greddy sp2 catback
dc 4-1 headers
valvetrain max rev at 12,000rpm
hondata s300(obd1)
gsr tranny w/lsd
so will it handle 9500-10000rpms?
Old Aug 27, 2008 | 08:41 AM
00b20vtecoupe's Avatar
Default Re: ls/vtec handling stress?9,500rpm?told it could safely... (671XxDaRkCyDexX)
honestly what are you doing about fuel?? fuel pump? injestors? fuel rail? and i would get a girdle for your crank. other than that all depends on your tune if your motor isnt making power up there then theres no reason to swing it that high...
Old Aug 27, 2008 | 08:45 AM
Default Re: ls/vtec handling stress?9,500rpm?told it could safely... (00b20vtecoupe)
and 9500 seems very extreme for that setup. That header is choking you to death and what about intake manifold and throttlebody? Those ctr pistons in an ls block usually comes out to being reallly high compression ive seen setups with upwards of 13 cr.
Old Aug 27, 2008 | 08:48 AM
98vtec's Avatar
moderator emeritus
why?
Old Aug 27, 2008 | 09:04 AM
mar778c's Avatar
Community Builder
Community Influencer
Looks like another collection of parts.
Old Aug 27, 2008 | 09:15 AM
girdle and rc 440cc injectors will come as soon *** the money comes fuel rail is obx from brother i use 91 octane
Old Aug 27, 2008 | 11:09 AM
98vtec's Avatar
moderator emeritus
Default Re: ls/vtec handling stress?9,500rpm?told it could safely... (98vtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98vtec &raquo;</TD></TR><TR><TD CLASS="quote">why?</TD></TR></TABLE>
Old Aug 27, 2008 | 02:57 PM
Phil M's Avatar
What does the dyno chart look like?
Just do it, Rev it to 9.5-10k with a stock head gasket!!
Let me get this straight..... you bought springs/retainers that are good for 12krpms but are using stock rods that are good for (guessing game) rpms.... You are using ctr pistons with a heafty compression height with a gsr head and which head gasket?
Mad tight VTAK rev to tha moon and be keeping up with rocket ships y0!!
Old Aug 27, 2008 | 06:33 PM
Default Re: ls/vtec handling stress?9,500rpm?told it could safely... (Phil M)
cometic head gasket
block guard helps too.
correction on the headers its a dc 4-2-1
Old Aug 27, 2008 | 06:47 PM
UncleD's Avatar
I bet you will peak power anywhere from 7,500~8k MAX. So why rev past 8,500 if that is the case? Using the 89 crank with those rpm's, your piston speed will be insane....will it last? Yes. How long? Not very.
Old Aug 27, 2008 | 07:00 PM
.I.Need.Money.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Phil M &raquo;</TD></TR><TR><TD CLASS="quote">
Mad tight VTAK rev to tha moon and be keeping up with rocket ships y0!! </TD></TR></TABLE>
LOL!!!
Old Aug 27, 2008 | 07:24 PM
DonF's Avatar
Default Re: ls/vtec handling stress?9,500rpm?told it could safely... (.I.Need.Money.)
I was told 9800 is max. to get 80,000 miles out of it. But I have seen Meth-Heads wrong before.Probably 50,000 miles, like the Oxy guy's said, I trust them more.
Old Aug 27, 2008 | 07:28 PM
goforbroke's Avatar
MEAT PATTY
Default Re: ls/vtec handling stress?9,500rpm?told it could safely... (clean rice)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by clean rice &raquo;</TD></TR><TR><TD CLASS="quote">I bet you will peak power anywhere from 7,500~8k MAX. So why rev past 8,500 if that is the case? Using the 89 crank with those rpm's, your piston speed will be insane....will it last? Yes. How long? Not very.</TD></TR></TABLE>
x2
Why the hell is everyone so rev happy. Thats why all these built motors only last for 15-20K especially LS/VTEC's because you guys want to rev your motors to the moon.
Thats something I never understood, whether its on here or real world experience with people I meet they always want to rev beyond whats needed. Its probably mad gangsta to rev to 12k like spoon does with their engines.
Old Aug 27, 2008 | 09:26 PM
mtber's Avatar
Default Re: ls/vtec handling stress?9,500rpm?told it could safely... (goforbroke)
Considering that setup won't be making positive power passed 8500 rpms reving it passed 9000 rpms is pointless.
Old Aug 28, 2008 | 04:53 AM
Default Re: ls/vtec handling stress?9,500rpm?told it could safely... (mtber)
exactly you rev to where you are making power to a lil bit more but there is no reason to be revving the motor 1000 to 1500 rpms past where you are making power... the people that do rev that high are people that are making power up there. If you are making power up over 9000 rpm's then rev "to the moon"... im making power up to 8800 to 9000 rpm's and you better belive im swinging to 9300 to 9500.
Old Aug 28, 2008 | 12:12 PM
98vtec's Avatar
moderator emeritus
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 00b20vtecoupe &raquo;</TD></TR><TR><TD CLASS="quote">exactly you rev to where you are making power to a lil bit more but there is no reason to be revving the motor 1000 to 1500 rpms past where you are making power... </TD></TR></TABLE>
wanna bet?
Old Aug 28, 2008 | 12:13 PM
IntegraType-R's Avatar
wanna bet?</TD></TR></TABLE>
ORLY...
lmao
blake your funny today..
Old Aug 28, 2008 | 02:59 PM
Fat Chick Magnet's Avatar
Why do you want to rev so high?
Old Aug 28, 2008 | 03:47 PM
Default Re: (Fat Chick Magnet)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Fat Chick Magnet &raquo;</TD></TR><TR><TD CLASS="quote">Why do you want to rev so high?</TD></TR></TABLE>
So gurls will *** when he sings his motor to 10.5k and shoots a piston to the moon..
OMFG THAT PISTON WAS MOVING SO FAST VTEC ALMOST KICKED ON OMFG
then your car died, and u got towed back home.. your going to get laid tonight.
Old Aug 28, 2008 | 04:21 PM
Phil M's Avatar
Default Re: (IntegraType-R)
haha its going to go zoom zoom zoom click click click boom!
Old Aug 28, 2008 | 04:26 PM
DonF's Avatar
Default Re: (Phil M)
Better than the old " I ran out of gas" excuse. Just more expensive, she better have a red thong.
Old Aug 28, 2008 | 04:51 PM
Default Re: (DonF)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DonF &raquo;</TD></TR><TR><TD CLASS="quote">Better than the old " I ran out of gas" excuse. Just more expensive, she better have a red thong.</TD></TR></TABLE>
Old Aug 28, 2008 | 09:22 PM
i love the high rev!!and its just something bout vtec...i also have a dc5 type r motor bought for 1400 bucks in guam it ran a 12.5 stock with a hondata k pro.but it was in a dc2 got the motor off from my good friend and my mechanic.i stay so close to japan so
the deals i get are great.i built my l/s vtec for only about 2000 bucks including the hondata s300(obd1)labor too.
Old Aug 29, 2008 | 01:10 AM
Default Re: (671XxDaRkCyDexX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 671XxDaRkCyDexX &raquo;</TD></TR><TR><TD CLASS="quote">i love the high rev!!and its just something bout vtec...i also have a dc5 type r motor bought for 1400 bucks in guam it ran a 12.5 stock with a hondata k pro.but it was in a dc2 got the motor off from my good friend and my mechanic.i stay so close to japan so
the deals i get are great.i built my l/s vtec for only about 2000 bucks including the hondata s300(obd1)labor too.</TD></TR></TABLE>
yeah well look into a dart block to rev to 10,000 rpm.
Old Aug 29, 2008 | 06:25 AM
Phil M's Avatar
yeah well look into a dart block to rev to 10,000 rpm.</TD></TR></TABLE>
Or at least get REAL rods.......
What is your piston to deck height? Piston to head clearance?
These things might "kiss" your motor good bye if you get higher up in the revs.....
Good luck.
Slowp0ke
12
Mar 24, 2011 09:40 AM
H-allmotorda9
Mar 13, 2010 05:08 AM
juggsda6
May 29, 2008 09:24 AM
rev-speed
87
Dec 1, 2007 03:55 PM
awdriscol4
Dec 30, 2004 11:16 PM
