Need help ASAP!
Old Aug 27, 2008 | 06:24 AM
hondachris1994's Avatar
Default Need help ASAP!
Well a wk ago my timing belt broke, wso I picked up another head, torqued the head down, when I put the cams on and torque all the cam cap bolts, for some reason the intake cam is hard to spin. Ive tried different cam caps and i have also tried different cams, and everytime the intake camshaft is hard to turn, and this is with the timingbelt off. The pistons are all middle stroke so that the valves would never touch anything. Im confused ive took them off several times and tried different caps and cams. WTF????
Old Aug 27, 2008 | 08:38 AM
bump for some help
Old Aug 27, 2008 | 09:18 AM
instructor74's Avatar
Default Re: (hondachris1994)
are you using the cam and cam caps from your old head or the ones that belong to the head you are installing on the car
Old Aug 27, 2008 | 09:40 AM
zacatkings's Avatar
Default Re: (instructor74)
Use the timing belt itself to turn the cams.
Put it on the cam gears and use it for leverage.
Old Aug 27, 2008 | 09:46 AM
demian22's Avatar
Default Re: (zacatkings)
Have you check your valves clearence?
Old Aug 27, 2008 | 11:11 AM
sageuvagony's Avatar
Next time try posting the problem in the thread title so people will bother reading your threads instead of writting "Need help ASAP!"
Old Aug 27, 2008 | 12:28 PM
blk92_d16's Avatar
There's supposed to be resistance, to some extent. Yes, only use the original valvetrain to that head...not from the other (just in case you are).
Old Aug 27, 2008 | 07:36 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by instructor74 &raquo;</TD></TR><TR><TD CLASS="quote">are you using the cam and cam caps from your old head or the ones that belong to the head you are installing on the car</TD></TR></TABLE>ive tried both
Old Aug 28, 2008 | 04:47 AM
anyone?
MatakiRotorD16
Jul 24, 2011 07:43 PM
Addicted 2 Adrenaline
Apr 14, 2009 09:07 PM
CPT.PANDA
Nov 5, 2007 01:02 PM
Nigel379
Jul 23, 2007 01:32 AM
nexgen91
Jan 21, 2007 10:19 AM
