Old Mar 25, 2015, 09:22 AM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Engine and Powertrain
Print Wikipost
94 accord ex power steering fluid bleeding
Old Aug 27, 2008 | 06:08 AM
danmaine's Avatar
Default 94 accord ex power steering fluid bleeding
Just replaced the alternator and power steering pump on my 94 EX
alternator working great, power steering fluid just keeps foaming and overflowing the bottle on the side of the fender well.
How the hell do I bleed this system to get the air out????!!!!
I've picked up a bottle of the Honda specific fluid...
I've started the car and let it sit for the bubbles to go out several times to no avail...
Help please!
Thanks
Dan
Old Aug 27, 2008 | 06:23 AM
Ross 2.0's Avatar
In a Junkyard near you.
Are yo sure that it's not sucking air with the pump running? Check the lines you took loose to see if you have any bad connections.
Old Aug 27, 2008 | 06:28 AM
danmaine's Avatar
Default Re: (Ross 2.0)
no loose lines, only removed the two lines where the bolt to the pump. O rings are intact, fully tightened etc...
poor design/parts location, the bottle isn't at the top of the system so it doesn't bleed easily
Old Aug 27, 2008 | 06:29 AM
Ross 2.0's Avatar
If you're sure it's not sucking air. Start the car and turn the steering wheel back and fourth lock to lock several times and it should purge the air.
If not you might have a bad pump or a kinked line.
Old Aug 27, 2008 | 07:30 AM
danmaine's Avatar
I did that too... I'm ythinking that the pump is bad. I got it because the old one squeeked sometimes on starting the car, it stopped if I sprayed lube into the bearing behind the pulley.
This one squeels all the time... very noisy pump... I guess that a boneyard pump wasn't a great idea...
Old Aug 27, 2008 | 08:01 AM
spoonfedcrx's Avatar
those things are a pain in the ***. i usually just top it off start the car and shut off after a few seconds. go refill and start again, do this until the fluid is leveld off for the most part then just turn wheel lock to lock.
Old Aug 27, 2008 | 08:37 AM
guymontag's Avatar
Fortunately, this is probably the last time you'll have to touch the power steering fluid for at least another decade.
Old Aug 28, 2008 | 07:58 AM
danmaine's Avatar
Default Re: (guymontag)
IT was a bad replacement pump! different pump start and let it sit twice, 20 minutes and a few ounces of oil later, all done
what a pita
FMohlmann
Nov 18, 2016 12:28 PM
76 camaro car
Mar 15, 2016 03:25 PM
jordy478
Jun 26, 2012 03:10 PM
JBirch_97Prelude
Dec 6, 2007 07:53 PM
radeonboy
Oct 12, 2007 07:14 AM
