99-00 b16 unleaded gas?
your fine... i use 87 on my b16 all the time with ITR cams and header back exhaust and i run strong. 91 makes me run rich and i smell gas all day...
also i did open my spark plugs up a bit and tuned it for 87...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by noender »</TD></TR><TR><TD CLASS="quote">im buying a 99 civic ex with a a b16 swap and i was in fueleconomy.com and it said that the b16 uses premium gas what happen if i use unleaded gas 87?
I'm running a '99 B16A2 swap in a '98 HX shell...
Regular 87-octane unleaded runs MUCH better (all around) than premium - as long as you use good gas, like Chevron, Shell, Texaco, et cetera!
The only time I hear any 'knock' is when I'm doing a warm start up - for like a millisecond in between cranking and starting...
It's like knock, knock, varoom... if that makes any sense!
With premium, you get no knock when warm starting, but it takes longer to fire up a cold engine, and it's not as responsive when you're driving it.
Premium gas kinda turns a B16 motor into a torqueless wonder - a slug - but it doesn't knock on a warm start. Whatever!
Fuel economy is the same, regardless of which fuel you use...
Anyway, it's your choice, but I'll never go back to premium unleaded!
</TD></TR></TABLE>I'm running a '99 B16A2 swap in a '98 HX shell...
do i need to set the spark plugs gap different then? and i had another question since it needs new piston rings and im planning on going turbo later on like in a year
i was thinking if ls piston would fit making me get lower compression? and if they do fit are they direct bolt on or do i need to do some work on the block?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99fbpem1 »</TD></TR><TR><TD CLASS="quote">honda reccommends premium and I figure they know what they are talking about.</TD></TR></TABLE>
x2
x2
it says on the si cluster itself "premium unleaded only", its a high compression engine so why would you take the risk of running a lower octane fuel? its like when you have a all motor or built turbo car you cant run b.s. gas unless you want it to detonate and there goes your motor.
i know its a high compression motor that why i ask if i get the ls piston would that lower my compression and run safe on the gas plus would this setup work for turbo 2 or just leave the stock pistons?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yessewey »</TD></TR><TR><TD CLASS="quote">it says on the si cluster itself "premium unleaded only", its a high compression engine so why would you take the risk of running a lower octane fuel?</TD></TR></TABLE>
Um...
Because I'm a man, not a sheep!?!?!
SOURCE
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">The American Petroleum Institute says if you find that your car runs fine on a lower grade, there is no sense switching to premium. The Institute recommends following manufacturer's recommendation, but even those manufacturers say that it is more of a suggestion than a command. </TD></TR></TABLE>
Um...
SOURCE
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mortificationrock »</TD></TR><TR><TD CLASS="quote">**** I use 90 octane on my y8.
Whatever!
Kinda like tossing quarters in a wishing well, IMHO...
</TD></TR></TABLE>Whatever!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlackDeuceCoupe »</TD></TR><TR><TD CLASS="quote">Whatever!
Well what's 90 octane?
When you have half a tank of 89 and go fill up and decide to put some 91. Jajajajaja......but seriously. I tried 91 yesterday and it runs like ****. I decided to try it for the heck of it. And it does suck.
</TD></TR></TABLE>Well what's 90 octane?
All gas in the USA is unleaded. People always have a habbit of calling 87 unleaded. It's all unleaded!
My friend's 92 Prelude SI with H23 says on the fuel door to use premium ONLY. He ran 87 when he first got it and the engine was knocking like a ****. 91-93 runs perfect on his.
On my D16Y7, I run 87. If I run 91 or 93, it doesn't run as good at all. It pisses me off when I see gas stations include those special additives ONLY to premium gasoline to encurage people to buy premium when their car does NOT need it. The oil companies do a good job of brainwashing people into thinking that 87 is HORRIBLE and premium is the way to go.
i run 93 in my b16..but im planning on going to 91 or 89 once i start commuting to college again..but yeh i agree..honda knowz what their talking about so use surpreme...its only a 3 dollaer difference if u fill up
