oil on plugs
Old Aug 26, 2008 | 08:11 PM
projcinco's Avatar
Default oil on plugs
just changed the head gasket put everything back together followed the steps it idled fine for about five, then i started noticing blue smoke coming out the exhaust, reved it a little and a cloud of blue smoke came out i checked the spark plugs and they were full of oil. i dont understand. it wasnt doing this before. were did i go wrong? or what do you guys think it is. i appreciate the help in advance. thnx
Old Aug 26, 2008 | 11:49 PM
HaulingAddison's Avatar
Default Re: oil on plugs (projcinco)
Sounds like the head gasket was put on backwards. I've heard you can put the gasket on backwards and it won't seal right. Other than that I don't know what else it could be.
Old Aug 27, 2008 | 01:12 PM
blk92_d16's Avatar
I really hope that didn't happen! But have you ever replaced the valve cover tube seals? They're inside the VC and seal the top of the spark plug tubes so that oil doesn't get in. Might wanna check those first to see if you're missing one or sliced one upon reinstalling.
BTW, is it leaking oil into ALL the tubes? or just one?
Old Aug 27, 2008 | 01:28 PM
Pothole987's Avatar
Default Re: (blk92_d16)
oil on plugs as in where it fires? or above? let the engine run for a bit incase theres alot of crap in it.
Did you change your oil after you changed the headgasket?
and i dont think you can put these gaskets on backwards, little differences in bolt holes.
Old Aug 27, 2008 | 04:20 PM
sageuvagony's Avatar
Oil on the upper half of the plugs means bad spark plug tube seals. They come in a gasket kit which includes valve cover washers/grommets, spark plug tube seals, and valve cover gasket. That wouldn't cause blue smoke though. If the bottom of the spark plug (spark tip portion) is drenched in oil, then your cylinders are filling up with oil which is the cause of the crazy smoke. This would indicate an improperly installed head gasket.
Old Aug 27, 2008 | 08:03 PM
projcinco's Avatar
Default Re: (sageuvagony)
its from where they fire. all four are kind of oily. anyone else have any other suggestions
Old Aug 28, 2008 | 10:03 AM
civ4life's Avatar
Default Re: (projcinco)
u may wanna check ur valve seals or the rings on ur pistons... blue smoke is usually an indication one of those two things getting bad... the oil in the in the spark plug is from the valve cover tube seal
Old Aug 28, 2008 | 03:10 PM
projcinco's Avatar
Old Aug 28, 2008 | 03:41 PM
BlackDeuceCoupe's Avatar
HT White Ops
Um...
Did your car overheat when you blew the original head gasket?!?!?
He so, your rings etc. are probably (ahem) toast...
Old Aug 28, 2008 | 06:10 PM
94EG8's Avatar
Seagull Management
Default Re: oil on plugs (BlackDeuceCoupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlackDeuceCoupe &raquo;</TD></TR><TR><TD CLASS="quote">Um...
He so, your rings etc. are probably (ahem) toast... </TD></TR></TABLE>
Yeah, pretty much. I put a headgasket in my first D15B7, i still to this day have yet to figure out what went wrong, i know the engine was heated bad enough, but it burnt way too much oil even for that, we're talking going through something like 3 litres of oil a day, in other words pretty much all of it. I've never seen anything smoke so bad in my life. I only ran it for a week and pulled in favor of another engine. But i'd still like to know why it burnt that much oil. But yeah, you overheat one of those engine and blow a headgasket and they're never the same again.
BlackSage
Oct 16, 2012 12:17 PM
Eg6xCiViCxSi
Dec 17, 2005 03:38 PM
.M.
May 22, 2005 03:08 AM
diewX3
Feb 24, 2005 04:08 PM
1.8Tea
Aug 27, 2004 07:54 PM
