turbo ls crx fuel question
Old Aug 26, 2008 | 07:40 PM
JWhonda_ride's Avatar
Default turbo ls crx fuel question
ok so i have a question on the limits of a stock ef fuel pump in my 91 dx crx. i swapped a b18a into it and am boosting it, its just a log style manifold, garrett .57 trim turbo and a johny race car intercooler. the wastegate has a 8lb spring in it, and i am using rc 440cc injectors, i also have a victor x intake manifold, the engine is completly stock at this point otherwise. and i was wondering if the stock fuel pump will be ok tuning my car to as much hp as i can get out of my settup which im assuming should be around 240whp from my understanding. i was just wondering if anyone out there has any experiences they would like to share and any other input. thanks a lot.
Old Aug 26, 2008 | 09:30 PM
julioboostamante's Avatar
Default Re: turbo ls crx fuel question (JWhonda_ride)
you should be fine. had mine in a sohc turbo set up and at 10 psi it did well. i have since upgraded to a Xenocron High flow pump due to the new set up and 17 psi of boost.
ahmongboi
Mar 27, 2010 06:10 AM
cleanazcoupe
Apr 19, 2009 10:00 AM
killablaze
Nov 14, 2005 05:47 PM
djnikko
Mar 7, 2004 09:47 AM
Jimmy
Jan 5, 2004 11:00 AM
