brake light problem.
Old Aug 26, 2008 | 07:07 PM
98integralsB18's Avatar
Default brake light problem.
ok i got a 90 crx with a b16 swap in it i dont have the cluster or anything in it yet and no headlights or corner lights in the front. I dont know if that is causing the problem or not but i have running lights and turn signals but when i press the brake and the brake lights have a faint flicker when ever they want when i pump the brake. i changed bulbs and checked wiring and fuses under the dash and in hood. the only thing i can think of is check every inch of wire from the rear lights and make sure there are no breaks or anything and change the brake cycinoid. dont know if anyone ele had the same problem. i know its a lot but thanks.
Old Aug 26, 2008 | 09:21 PM
khooper's Avatar
Default Re: brake light problem. (98integralsB18)
You can check the brake switch. It's attached to the brake pedal assembly under the dash. Unplug the switch and use a wire to jump the two pins. If the lights turn on it's the switch.
_______________________
Autopartswarehouse Addict
CR-X_B20
Jul 6, 2013 06:36 PM
gsxr-t-bag600
Dec 27, 2011 09:51 PM
PREACHERBREW
Jun 5, 2008 01:12 PM
Captain JDM
Oct 23, 2006 11:35 AM
sadiusomega
Jul 27, 2005 08:43 PM
