piston rod confusion
Old Aug 26, 2008 | 07:05 PM
KraKimus's Avatar
Default piston rod confusion
so i bought pistons and rods for my 93 h23 and they came seperatly and i wanna know how to put them together
Old Aug 27, 2008 | 06:19 AM
KraKimus's Avatar
Default Re: piston rod confusion (KraKimus)
bump bump bump it up bump bububump bubububububump
Old Aug 27, 2008 | 06:27 AM
98vtec's Avatar
moderator emeritus
the wrist pins have to be pressed in. Go to a machine shop.
Old Aug 27, 2008 | 06:40 AM
KraKimus's Avatar
Default Re: piston rod confusion (98vtec)
so they HAVE to be done at a machine shop?
Old Aug 27, 2008 | 06:46 AM
98vtec's Avatar
moderator emeritus
unless you have a press and can use it properly.
consult your service manual.
Old Aug 29, 2008 | 06:54 AM
KraKimus's Avatar
BUMPUMPUMPUMPUMPUMPUMP UMP
Old Aug 29, 2008 | 07:39 PM
JTCdudeman's Avatar
Master H Technician
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KraKimus &raquo;</TD></TR><TR><TD CLASS="quote">BUMPUMPUMPUMPUMPUMPUMP UMP</TD></TR></TABLE>
Why the hell did you bump this?
You got your answer... This is not an opinionated matter...
Old Aug 30, 2008 | 06:33 AM
KraKimus's Avatar
Default Re: piston rod confusion (JTCdudeman)
because i think theres gotta be another way.....other wise do people rebuild motors at home?
Old Aug 30, 2008 | 06:42 AM
98vtec's Avatar
moderator emeritus
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98vtec &raquo;</TD></TR><TR><TD CLASS="quote">unless you have a press and can use it properly.
consult your service manual.</TD></TR></TABLE>
Old Aug 30, 2008 | 08:56 AM
JTCdudeman's Avatar
Master H Technician
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KraKimus &raquo;</TD></TR><TR><TD CLASS="quote">because i think theres gotta be another way.....other wise do people rebuild motors at home?</TD></TR></TABLE>
Ok... Well, different motors are setup different ways. Your setup has specific requirements. Hard to argue with people who have built plenty of motors before, but your trying hard enough. Its easily possible to build your motor at your house.. You can press them in yourself in you have the tools as said by 98vtec. But, if you mess up.. Time to buy new pistons. Its just not worth it if your clueless, which you are because your asking us how to do it.
Most people pay a machine shop $40 or less to press them in and then take the whole setup back to the house and do the install.
aznomb
Jul 15, 2008 04:18 PM
TmeX05
Aug 21, 2006 09:28 PM
SleeperDC2_ZzZ
May 15, 2006 08:44 AM
SwissChEz82
Aug 9, 2005 03:15 PM
