Code 12 B16A
Old Aug 26, 2008 | 06:28 PM
doom26464's Avatar
Default Code 12 B16A
ok check the codes on my pr3-j00 ecu
got one slow blink followed by 2 fast blinks...So I think that would make it code 12. Code 12 is EGR. I didn't even know JDM b16 had EGR's? How Do I go about fixing this one?
Old Aug 26, 2008 | 07:00 PM
gringo7718's Avatar
Default Re: Code 12 B16A (doom26464)
https://honda-tech.com/zerothread?id=235459
Try resetting your ECU again, maybe it was a fluke? or perhaps you are misreading the code? To reset the ecu pull the 10amp hazard fuse from the underhood fusebox for 30 sec.
Old Aug 26, 2008 | 07:05 PM
doom26464's Avatar
i will try reseting and see if it comes back. Unless its some how code 1 and 2 right after each other.
Old Aug 26, 2008 | 07:12 PM
gringo7718's Avatar
Default Re: (doom26464)
each code by themselves makes sense.
one long blink would suggest code 10 (IAT sensor)
two short blinks would suggest code 2 (2nd O2 sensor)
Old Aug 26, 2008 | 07:45 PM
doom26464's Avatar
mabye its code 1 primary o2 sensors and then 2 quick blinks after being code 2 2nd o2 sensor?
man reading codes on these damn things is pretty hard
got_no_sol
Mar 13, 2017 07:28 AM
scarface50370
Dec 14, 2005 01:21 AM
aHOLE
Feb 20, 2003 04:50 PM
