92-95 Honda Civic Fog Lights Installation???
Hey Wats Up I Got Another Dumb Question...
I Bought The Fogs Lights And It Didnt Come With
Instructions To How To Install Them... Ok I Know
How Everything Goes Its Just One Red Wire That Is
Messing Me Up I Dont Know Where It Goes
This Red Wire Is From The Cable That Connects To The Switch
Help Please
Modified by 9.3.S.I.L.U.D.E. at 11:25 AM 8/27/2008
Help Please
well scince ur pics are not working for me. this is gona be a guess scince i have the same fogs.
do you have the entire harness for th fogs?
the red wire to the switch conects to the red wire from the harnes to the fog lights witch connect to the battery.
then the yellow wires on the switch u connect to your fuse box underneath the dash. i think you put it in the 4th spot my pic is pointing at the fist. you put it there so that the switch will only turn on if your parking lights are on and/or headlights. so that you wont accidently forget to turn them off unless you leave ur headlights on.
then of course your black wire is your ground.
is there anything els you need.
or is your harness completly different.
ALRIGHT COOL.....PROBLEM FIXED IT WAS RED SO I FIGURE THATS POWER
SO I JUST CONNECTED IT TO SOME POWER CABLE AND IT WORKS NOW N E WAYS THANKS ALOT
what i did was go to autozone and got a PILOT fog light wiring harness. It gives you instructions on how to wire them and it comes with a switch. don't wire into the fuse box because you'll blow fuses. I tried it and I had nothing but problems. Use car battery as a power source.
what r u talking about... dude it will only blow fuses if you don't know how to hook **** up.
i have never had any problems with my fogs. and ive had them for almost a year now.
My bad... I didn't know how to hook up my fogs and I went to a lot forums to ask advice and I took some advice that was bad like splicing the fogs into the corner light wiring harness. VERY BAD. that's what blew fuses. Forgot to mention that. I was in the same situation and I was trying to give another alternative.
Follow this and you should be good: http://www.hondaautomotivepart....html
ShakesTheKlown
Mar 29, 2004 09:19 AM
