P73 + Knock Sensor + LS VTEC = YES or NO?
Old Aug 26, 2008 | 04:19 PM
paton5g's Avatar
Default P73 + Knock Sensor + LS VTEC = YES or NO?
I'm installing an LS VTEC into my Integra (OBDII) and running a P73. Does this ECU have to see a knock sensor to correctly operate?
I have aftermarket 12.1:1 pistons and I was told that the sound of the pistons will trick the knock sensor into thinking there's detonation. True or false?
Old Aug 26, 2008 | 09:38 PM
mtber's Avatar
Default Re: P73 + Knock Sensor + LS VTEC = YES or NO? (paton5g)
Yes a p73 looks for knock. The piston's won't trick anything. If you in fact have detonation your knock sensor will possibly pick it up (bseries knock sensors kinda suck).
The best solution would be to use a chipped obd1 vtec ecu for your setup
Old Aug 27, 2008 | 03:44 PM
paton5g's Avatar
Default Re: P73 + Knock Sensor + LS VTEC = YES or NO? (mtber)
so it would have to be an obd1 ecu with a jumper harness to plug into my obd2 integra?
Old Aug 27, 2008 | 09:56 PM
mtber's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by paton5g &raquo;</TD></TR><TR><TD CLASS="quote">so it would have to be an obd1 ecu with a jumper harness to plug into my obd2 integra?</TD></TR></TABLE>
Correct
Old Aug 27, 2008 | 11:40 PM
ahobbs's Avatar
HELLO,GOOD MORNIN'
get the right one for your yr model
Old Sep 22, 2008 | 07:28 PM
acurious96's Avatar
Try HASPORT.COM!!! You need the OBD 1 knock sensor/VTEC solenoid subharness. It costs about 104 dollars 2 day air from Cali. shipping included. this will send you everything you need to wire knock and VTEC up from your OBD 1 ECM to the engine. it installs like a foctory harness. the only wire in you will physically have to do is at the ecm connector pins. I would reccomend the use of an OBDv 1 ECM as a side note. you can find one of the best ECM pinouts for your ECM connector at Technet.ff-squad.com good luck.
toyotat100
Oct 15, 2014 07:57 PM
ToTriggerHappy
Apr 20, 2010 07:02 AM
ys1civic
Aug 13, 2006 07:39 PM
allmotorchick
Apr 4, 2006 09:32 AM
slayersluck
Dec 30, 2004 06:00 PM
