Quick Question on Tire size and Fitting?
Hey guys i have a 97 Accord SE and the recommended tire size for this car is a 185/65r15 but i have 2 brand new 205/60r15 that i would like to put on the front of the car would i run into a problem with this fitting in the front rubbing on the width?
thanks guys
thanks guys
I believe the stock size is 195/60-15. If your car is not slammed, the tires will work just fine, and you will have no rubbing issues. Keep in mind that your speedo will be off by ~1%.
yep, it will fit just fine. 205/55 r16 will also fit fine. But you may have to check the rims offset
Modified by acco at 5:26 PM 8/26/2008
slammed_93_hatch
Jul 16, 2003 06:44 PM
