Tire Size Q
Re: Tire Size Q
Thanks Matt, for pointing me in the right direction BTW
Re: Tire Size Q
OP: 205/45R16 would probably be the most ideal tire size to go with.
the numbers 215/35R18 signify tire width, height(aspect ratio technically) and diameter. In your case you have:
215: this means you have a tire that is 215mm wide.
35: this means you have a tire height(aspect ratio) that is 35% of the width of the tire(215).
18: this mean you have a wheel diameter of 18". So, to answer your question, you have 18" wheels. How wide your wheels are, we cannot determine from tire size.
So, again, you have 18" wheels. I am only going to assume from the tire size you currently have that you have a 4th gen Prelude, correct(need to know to determine correct tire size)?. If so, you NEED to use a 215/35R18 to get the closest to stock overall diameter. If you use a 215/40R18 tire, you increase the overall diameter of the wheel/tire and this throws off your speedometer even more and decreases gas mileage and performance.
I'd suggest going with a smaller wheel, 18" wheel is huge even on a Prelude.. Better look(IMO), better ride quality, better performance and cheaper tires.
hey have a quick question for myself! lol
I have 215/35/18 tires on my Prelude right now... I actually don't know what size me RIMs are though... Does that mean my RIMs are 18" as well or are they 17"? Or could my RIM be either of these sizes to fit my tire? :S
And one other question is, can I put a 215/40/18 on there instead of the 35?
Sanji
Re: Tire Size Q
I have the exact same rim specs/size on my Integra sedan. I went with 205/45-16's. No rubbing issues at all, great tire choice for that wheel size. No fender rolling involved either = WIN.
[IM G]https://lh3.googleusercontent.com/_DBMGIkHT6KU/TbZuB7E5CBI/AAAAAAAAAf0/nLRFhLHiFaI/s800/DSCN1292.JPG[/IMG]
Re: Tire Size Q
Ive done 195's,205's, and 215's (slight rub issues, different car though)...I don't tend to prefer 1 over another. I prefer to pay attention to the quality and make of tire at that point. 10mm "wider contact" really wont do much to be honest. Quality is and price is what you should be debating on at this point.
Hope this didn't cause any confusion. GL OP
