Hey guys about h23 swap over to h22 please help!
hey i found a guy who has a h22 with ecu,harness, and lsd 5speed transmission. he is giving me it for a good price but i was wondering what extra parts would i need? headers intake manifold..? also i have an automatic, i got it that way. so with the 5 speed tranny what else would i need for the full conversion. anyhelp would be great.
at the moment i have the h23a1 with automatic tranny installed.
That is parts list for doing a H23 to h22 swap. read it more careful, there are more things you should just do when just swapping in a motor, like changing gaskets, and cleaning more crap out.
I added more info
I added more info
youl need an h22 header, intake is the same, youl need the shift linkage and shifter assembly, pedal assembly clutch hydraulic lines ect
^^ Intake is the same, but intake MANIFOLD is different between the H22 and H23, but I assume the engine will have the intake manifold. Sounds to me like you need a header, all the parts for an auto/manual swap, i.e. shifter assembly and cables, pedal assembly, master cylinder, fluid reservoir, hydro lines etc. as stated. Some people seem to have issues with the tranny side motor mount on the frame, so that could be worth looking into as well.
You will need, shifter box w/cables, pedal assembly with master cylinder and the hard line that runs fluid from reservoir to the hydraulic line, Your also going to need the trans mount and the rear t bracket if they are not included with the swap. If you want to do things legit you will also need m/t center console and m/t cluster. Also be careful with that tranny because if it isn't a jdm oem lsd you might get shafted depending upon the product, check the trans code it should be M2B4 if oem.
totumspiretfoxx
Nov 14, 2016 04:27 PM
