timing belt guide question
Old Aug 26, 2008 | 07:00 AM
rwcdrums's Avatar
Default timing belt guide question
I'm putting a newly built motor together and when I went to put the timing belt on I noticed I only had one belt guide plate and I thought there was supposed to be 2 of them. I checked the helms manual and it only shows one and then I checked my haynes manual and it says some have 2 and some only have one. I just need to know how many there are supposed to be and if only one which side does it go on. Thanks
Old Aug 26, 2008 | 07:55 AM
1992Si's Avatar
Which engine?
Just make sure you put it on faceing the correct direction. The rounded side guides the belt.
If you only have one, may be your's only came with one.
Old Aug 26, 2008 | 08:19 AM
rwcdrums's Avatar
Default Re: (1992Si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1992Si &raquo;</TD></TR><TR><TD CLASS="quote">Which engine?
Sorry it's a b18c. Well I don't know if it only came with one or I lost one. It has been about a year since I took the old motor apart and I have moved twice since then so I that's why I'm not sure. thanks for the input though.
Old Aug 26, 2008 | 10:46 AM
rwcdrums's Avatar
Default Re: (rwcdrums)
bump for some more input
Old Aug 26, 2008 | 03:35 PM
rwcdrums's Avatar
Nevermind. Found my answer
ZXRider
Dec 31, 2006 04:07 PM
maiv01
Dec 9, 2005 02:02 PM
accordredliner
Jun 15, 2005 10:21 AM
OzWolfbane
Jan 7, 2005 05:14 PM
RacerZook
Jan 6, 2004 04:52 PM
