Head gasket reuse?
Old Aug 26, 2008 | 06:53 AM
z0om's Avatar
Default Head gasket reuse?
I just got a new head gasket, put the head back on, torqued it all down, then discovered some stripped threads in the head for one of the cam cap bolts.
Anyways, I'm going to pull the head back off and fix it. Is it okay to reuse a head gasket in this condition, or is it recommended to replace, even when the motor has never run?
Thanks!
Patrick
Old Aug 26, 2008 | 08:46 AM
Flashmn's Avatar
Default Re: Head gasket reuse? (z0om)
Thats what I've been told. Replace it even if the motor hasnt been used.
Old Aug 26, 2008 | 10:29 AM
1992Si's Avatar
You'll be replaceing it with a new one either now or later.
Old Aug 26, 2008 | 11:04 AM
Dartanian's Avatar
Copper spray.
I ran thousands of boosted miles using an old headgasket coated with copper.
Old Aug 26, 2008 | 05:33 PM
DonF's Avatar
Default Re: Head gasket reuse? (Dartanian)
You will be fine.
Old Aug 27, 2008 | 07:37 AM
z0om's Avatar
okay, sounds like reuse should be fine, especially if i use some copper spray too.
thanks,
patrick
Old Aug 28, 2008 | 03:50 PM
srmofo's Avatar
depends on how much you like changing headgaskets, yeah it may be alright for now, but it may not be tomorrow...I dont like to half *** things, appearently some do...how much is a new gasket? paper HG are what 25$, MLS are like $60, its worth 4 hours of my life to not have to do the job for the 3rd time
Old Aug 28, 2008 | 04:12 PM
mahdavimotorsports's Avatar
Default Re: Head gasket reuse? (srmofo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by srmofo &raquo;</TD></TR><TR><TD CLASS="quote">depends on how much you like changing headgaskets, yeah it may be alright for now, but it may not be tomorrow...I dont like to half *** things, appearently some do...how much is a new gasket? paper HG are what 25$, MLS are like $60, its worth 4 hours of my life to not have to do the job for the 3rd time</TD></TR></TABLE>
X2
E85B18
Mar 8, 2010 02:34 PM
lilshady6796
Feb 3, 2009 07:59 PM
da_33
Jan 11, 2007 11:12 AM
DLB1994
Feb 23, 2002 08:10 PM
