What will work best for my setup?
Old Aug 25, 2008 | 10:10 PM
DanteUrban's Avatar
Default What will work best for my setup?
Its a 2000 Si with an Intake and Header. I would like a full catback exhaust and new cams. Maybe a new intake manifold (but I heard the stock one was good for all rpm power) I would just like a quick power boost. Thanks.
Old Aug 25, 2008 | 11:07 PM
wh1zd0m's Avatar
Default Re: What will work best for my setup? (DanteUrban)
I gotta 00 si also with an all stock jdm b16. and in my opinion Dante the only thing you should do to that car is the cat back exhaust and keep it well maintained.
Old Aug 26, 2008 | 08:03 AM
DanteUrban's Avatar
Default Re: What will work best for my setup? (wh1zd0m)
I just want new cams for more power. I use my car as a daily driver, and it would be fun to have a little bit more power. And I need to find an exhaust that will work with my setup. Plus I need to find out how big it should be.
Old Aug 26, 2008 | 08:38 AM
00b20vtecoupe's Avatar
get a good exhaust i have the same car get an RSR exmag its quiet and top quality and it sounds amazing. Good power gains and its like 2.3 or 2.5 inch so its good
Old Aug 26, 2008 | 11:41 PM
DanteUrban's Avatar
Default Re: What will work best for my setup? (00b20vtecoupe)
Now I just need some advice on getting some cams.
Old Aug 27, 2008 | 06:49 AM
DanteUrban's Avatar
Anyone got any ideas?
Old Aug 27, 2008 | 07:06 AM
MurdersV8s's Avatar
Do you still want reliability? You cannot go wrong with a set of itr cams. Just make sure to get the most recent design and matching valves, springs and retainers. Not only do you gain power, but you still have honda reliability. Oh ya don't forget to get it tuned.
Old Aug 27, 2008 | 07:10 AM
why do you want cams? there are alot of other things to get before cams... putting cams in your gonna wanna get valve springs and retainers, probably upgrade intake manifold, need a tune... i wouldnt if your trying to stay inexpensive and low key...
Old Aug 27, 2008 | 07:16 AM
jgraham0326's Avatar
Yeah man either Itr or Ctr cams would be good maybe throw some better springs and retainers in as well man. good luck on your build!
Old Aug 28, 2008 | 06:25 AM
DanteUrban's Avatar
Default Re: What will work best for my setup? (jgraham0326)
I'm def. going to get it tuned after they are installed. Because there is a place around here that does that kind of stuff and they have a dyno that they tune on.
Old Sep 2, 2008 | 09:31 PM
DanteUrban's Avatar
Bump.
PRLSV
39
Apr 5, 2012 12:39 PM
negusjuda
16
Mar 21, 2012 01:05 PM
jordan_civic
Aug 7, 2007 10:20 AM
sportcompactsolutions
16
Oct 8, 2004 05:28 PM
