What will work best for my setup?
Its a 2000 Si with an Intake and Header. I would like a full catback exhaust and new cams. Maybe a new intake manifold (but I heard the stock one was good for all rpm power) I would just like a quick power boost. Thanks.
Re: What will work best for my setup? (DanteUrban)
I gotta 00 si also with an all stock jdm b16. and in my opinion Dante the only thing you should do to that car is the cat back exhaust and keep it well maintained.
Re: What will work best for my setup? (wh1zd0m)
I just want new cams for more power. I use my car as a daily driver, and it would be fun to have a little bit more power. And I need to find an exhaust that will work with my setup. Plus I need to find out how big it should be.
get a good exhaust i have the same car get an RSR exmag its quiet and top quality and it sounds amazing. Good power gains and its like 2.3 or 2.5 inch so its good
Do you still want reliability? You cannot go wrong with a set of itr cams. Just make sure to get the most recent design and matching valves, springs and retainers. Not only do you gain power, but you still have honda reliability. Oh ya don't forget to get it tuned.
why do you want cams? there are alot of other things to get before cams... putting cams in your gonna wanna get valve springs and retainers, probably upgrade intake manifold, need a tune... i wouldnt if your trying to stay inexpensive and low key...
Re: What will work best for my setup? (00b20vtecoupe)
Yeah man either Itr or Ctr cams would be good maybe throw some better springs and retainers in as well man. good luck on your build!
Re: What will work best for my setup? (jgraham0326)
I'm def. going to get it tuned after they are installed. Because there is a place around here that does that kind of stuff and they have a dyno that they tune on.
sportcompactsolutions
16
10-08-2004 05:28 PM
