bet all 16 valves? need quick help
Old Aug 25, 2008 | 09:30 PM
Evil Smile's Avatar
Default bet all 16 valves? need quick help
hey guys
i bought an RSX with a bad engine. it had spun a bearing and completely crushed it. well i took the car apart and dropped the parts at the machine shop. today the machineshop calls me and tells me that when he took the head apart to clean it off all 16 valves were bent. is this guy trying to rip me off or is this possible? engine has 90k and the last owner obviously didnt car for the car very much.
thanks in advace
Old Aug 25, 2008 | 09:42 PM
bokals's Avatar
Default Re: bet all 16 valves? need quick help (Evil Smile)
better to get them replaced anyway
Old Aug 25, 2008 | 10:14 PM
00Red_SiR's Avatar
All Motor Mentor
you never heard of bending all 16 valves before? it happens....
Old Aug 26, 2008 | 06:36 AM
Evil Smile's Avatar
Default Re: bet all 16 valves? need quick help (00Red_SiR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 00Red_SiR &raquo;</TD></TR><TR><TD CLASS="quote">you never heard of bending all 16 valves before? it happens....</TD></TR></TABLE>
is this serious or are you being sarvastic?
Old Aug 26, 2008 | 06:49 AM
ruffrhyder's Avatar
I've personally had a motor with 12 bent valves, all 8 exhaust and 4 intake and the car still ran, I didn't even know until I had the head taken apart while rebuilding the block just like you. So yeah, I can see having all 16 valves being bent. Ask the machinist to show you the valves before you order new ones. Sometimes it is very hard to even see the damage but its there.
Old Aug 26, 2008 | 07:42 AM
2fastGSR's Avatar
King of the One Liners
Default Re: bet all 16 valves? need quick help (ruffrhyder)
I think the problem is that when someone says "bent" they think of the valve being completely bent into a U shape.
A lot of times a valve can be bent ever slightly and will only get worse in time.
Same things can be said for rods. . I have seen motors with bearing problems bend a rod ever so much that an untrained eye would probably never see, but my machine shop could definitely tell. . .
Just get another set of valves and call it a day. Valves cost 2-300. Think of what it will cost if one of the current valves decides to drop on the highway. . .
Old Aug 26, 2008 | 01:54 PM
00Red_SiR's Avatar
All Motor Mentor
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Evil Smile &raquo;</TD></TR><TR><TD CLASS="quote">
is this serious or are you being sarvastic?</TD></TR></TABLE>
Yes I was being serious. Most of the time the valves are slightly bent and will still work but they really damage the valve seats and cause a lot of leakage around them if not replaced. Breaking a cam or timing belt or a slipping cam gear(s) will cause some noticable bending but it can and does happen.
Whonda
Oct 1, 2008 08:28 AM
cbabyby
Sep 11, 2007 08:50 PM
Coletrain
Apr 7, 2005 12:30 PM
jaxle
Oct 8, 2003 09:48 AM
mr. wu
13
Jun 17, 2003 08:58 PM
