My oil pan is leaking
Old Aug 25, 2008 | 07:09 PM
985HaysTown's Avatar
Default My oil pan is leaking
I have a 1991 Honda Accord LX and my oil pan is leaking about half a quart a day and Im considering on changing it. But Im not sure on how or what to do. So could someone please help me out.
Old Aug 25, 2008 | 08:34 PM
02 accord's Avatar
Default Re: My oil pan is leaking (985HaysTown)
Drain the oil, remove the old oil pan, put in the new one.
Old Aug 25, 2008 | 08:56 PM
Default Re: My oil pan is leaking (02 accord)
Well I know that, but how would you do it though? Is there anything else I would need to remove like exhaust or anything like that?
Old Aug 25, 2008 | 08:59 PM
02 accord's Avatar
How would I do it? I would undo all the screws and try to pull out the pan. If it didn't come out because something was in the way, I would remove that too. But that's just me.
Old Aug 25, 2008 | 09:02 PM
Thanks for your help. O Im considering on buying a one owner 1994 Honda Accord with 98,000mi. Even though its been sitting in the garage and hasn't been driven in a month. Would you consider this a good buy since Im getting it for $1,500?
Old Aug 25, 2008 | 09:24 PM
mavvrik's Avatar
Replacing your oil pan isn't exactly that easy.
Well, I mean, it's that easy, but in order to replace it you need to buy a enitrly new oil pan, oil pan gasket, and i believe another part....i can't remeber right now. I found this out when I thought my oil pan needed replacing. Go to your local Advanced, Checker, AutoZone, etc.. and they'll tell you everything that you'll have to replace.
Old Aug 25, 2008 | 09:51 PM
cjo_28's Avatar
Your oil pan alone is not leaking 1/2 quart a day. You probably have a rear main seal leak and your front engine seals are probably leaking too
Old Aug 26, 2008 | 09:48 AM
213374U's Avatar
0x5359-0055
Community Builder
Default Re: (mavvrik)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mavvrik &raquo;</TD></TR><TR><TD CLASS="quote">Replacing your oil pan isn't exactly that easy.</TD></TR></TABLE>
........... seriously!?!?!
Old Aug 26, 2008 | 10:03 AM
TouringAccord's Avatar
H-T Order of Merit
Well, I mean, it's that easy, but in order to replace it you need to buy a enitrly new oil pan, oil pan gasket, and i believe another part....i can't remeber right now. I found this out when I thought my oil pan needed replacing. Go to your local Advanced, Checker, AutoZone, etc.. and they'll tell you everything that you'll have to replace.</TD></TR></TABLE>
wait, why do you need to replace the oil pan if all you want to replace is the gasket? Someone told you the wrong info, don't go back to them for advice, unless there is something you are telling us.
to replace the oil pan gasket you don't need to replace anything else extra. Drop the down pipe, remove the center support beam of the front subframe and remove the oil pan, wipe everything clean and install in reverse order. Make sure you install in the proper sequence and torque spec.
Old Aug 27, 2008 | 11:36 AM
NGUSPEED's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 985HaysTown &raquo;</TD></TR><TR><TD CLASS="quote">Thanks for your help. O Im considering on buying a one owner 1994 Honda Accord with 98,000mi. Even though its been sitting in the garage and hasn't been driven in a month. Would you consider this a good buy since Im getting it for $1,500?</TD></TR></TABLE>
This is a good deal.
Are you still trying to replace the oil pan, or are you giving up and moving on?
Old Aug 27, 2008 | 05:09 PM
Default Re: My oil pan is leaking (NGUSPEED)
Im going to fix it but the car thar im about to buy is for my lil brother to drive.
Old Aug 28, 2008 | 01:50 AM
jwicecold's Avatar
That is a lot of oil leaking out. I would just change your oil pan as well, and the gasket. Also make sure no screws broke off. Its Easy to replace
Old Aug 28, 2008 | 09:10 AM
n_csmith's Avatar
Default Re: (jwicecold)
mine is doing the same thing not quite as bad but mine is just the gasket cause they guy i bought it from is a retard...im having to fix everything they already fixed its starting to **** me off, but still thats my fault for not looking at the car better before i got it. Im going to just replace the oil pan gasket cause i can clearly see that it is seeping from there.
nico08
Apr 24, 2016 01:15 AM
JDMBOB
Mar 9, 2008 10:56 AM
honda94accord
Sep 27, 2007 03:49 AM
TheYellowDart
Dec 17, 2004 07:51 PM
98 Ek LsVtec
Jul 29, 2001 11:13 AM
