84mm pistons
Old Aug 25, 2008 | 06:45 PM
ray on boost's Avatar
Default 84mm pistons
do they have type r pistons in 84mm or do i have to get custom?
Old Aug 25, 2008 | 06:49 PM
RTW DC2R's Avatar
OEM = no
Old Aug 25, 2008 | 07:07 PM
Default Re: (RTW DC2R)
I'm looking to put some 84mm type r's with ls rods and crank with full valve train. so I'm looking at je or wiseco i guess.
Old Aug 26, 2008 | 04:54 AM
Fink29's Avatar
Default Re: (ray on boost)
Search rs machines that make 84mm type r piston
Old Aug 27, 2008 | 04:58 AM
Default Re: (Fink29)
thanks. 1 more question. if I bore out my motor to 84mm should get sleves or is a block guard good enough? thanks again.
Old Aug 28, 2008 | 04:55 AM
anyone. just like to know the risk of boring to 84 and if I need sleves.
Old Aug 28, 2008 | 12:38 PM
Darton's Avatar
You will need to sleeve the block in order to run an 84mm piston. There is no wall left when you bore the stock cylinders that large.
enlque
Oct 30, 2010 01:05 PM
meanshyguy
Sep 7, 2008 08:28 AM
2000h22a
Jul 17, 2008 12:44 PM
mikeaitken
Apr 23, 2007 03:16 PM
Smurfylude
May 1, 2002 04:39 PM
