will si axles fit on the zc tranny?
what about ZC axles and intermediate shaft?
where can i get a zc intermediate shaft?
Hey Matthew, I put my si intake manifold on my zc it just bolted right up. But you are right about the si axles are a diameter than the zc cause i am having that problem myself right now.
THERE IS a way to use your old SI axles with the ZC tranny.
Use 90-93 integra inner joint on your SI passenger axle.
Use 85 Accord 5spd inner joint on your SI driver axle.
ALSO. THERE IS a possibility that there is a US intermediate shaft that will work with ZC: Civic WagoVan came with D16A6 AND used the Int. shaft setup.
I haven't heard of people trying this setup, but the logic says it should work.
If you ever do it - definitely post here about the results.
[Modified by nikitad, 8:17 AM 7/31/2002]
