power window problemmo
Old Aug 25, 2008 | 02:55 PM
v8 integra's Avatar
Default power window problemmo
my passenger side window doesnt go down but it goes up..it goes down when i push down on the window and it only goes up from the switch... what could it be? 96 civic ex thanks ht
*EDIT* so peeps can see what the other question is..
ok so i took the motor/regulator out and connected it directly to the battery and i had the same problem..the window only going up and not down..is it possible for the window motor to only work one way??? i just wanted to make sure b4 i buy a new regulator/motor and where would be the best place to buy a window motor or regulator w motor besides majestic honda..
Modified by v8 integra at 9:44 PM 8/30/2008
Old Aug 25, 2008 | 03:07 PM
sageuvagony's Avatar
Default Re: power window problemmo (v8 integra)
Try spraying silicone spray along the window tracks making sure you move the window up and down during the process. DON'T USE WD-40! Use silicone spray. Solved my slow/non-rolling windows problem!!
Old Aug 25, 2008 | 03:55 PM
v8 integra's Avatar
Default Re: power window problemmo (sageuvagony)
idk if thats the problem..the window rolls up perfectly fine..but wen i push the button to make the window go down it doesnt at all..like completly dead from both the driverside and passenger switch
Old Aug 25, 2008 | 05:54 PM
craigaria's Avatar
I have the same problem. But mine will only roll up from the pass. switch, and it won't do anything from the drivers switch. I tested my motor and it is good, and I also replaced the switches (driver and pass.) and I still have the same problem. I'll let you know if I figure it out...
Old Aug 25, 2008 | 06:39 PM
Default Re: power window problemmo (craigaria)
My driver window would roll up perfectly but would only roll down half way, but that was due to friction which silicone spray fixed. You're saying that when you push on the down switch, you hear NOTHING? No motor click or ANYTHING? just dead dead dead? If it's dead dead dead, it may be the switch switch switch . . .
Old Aug 25, 2008 | 09:54 PM
v8 integra's Avatar
but theirs 2 switches..1 on the driver side and 1 on the passenger side..how would both go bad at the same time..their not click or any budging wen i push the down switch..
Old Aug 26, 2008 | 11:00 AM
v8 integra's Avatar
anyone know??? and yes when i push the it down with the switch i dont hear anything no click or movement..but if i push it down with my hands and then roll it back up with the switch it goes up perfectly fine
Old Aug 26, 2008 | 01:04 PM
v8 integra's Avatar
bump
Old Aug 26, 2008 | 02:07 PM
v8 integra's Avatar
buuummmpp
Old Aug 27, 2008 | 10:18 AM
v8 integra's Avatar
comeee on!!!!! where the master mechanics at!!!!!
Old Aug 27, 2008 | 11:25 AM
craiger28's Avatar
If it rolls up but doesn't roll down unless you push it down. That really sounds like the window switch. Take the switch out of the door with it still hooked up to the wires and with the key on tap on the back of the switch and or wiggle the wires and see if that makes the window motor work and go down. If it goes down it is the switch. But you are saying that it doesn't go down on either switch correct? If that is the case: On the drivers side door you have a master switch module under the door panel. I believe it is brown or orange in color, it could be that. You would need to test it. Any friends have a integra like you? If so you can switch parts safely to check it. Let me know what happens when you tried all these. I might have more suggestions that require more work. always think of the simple stuff first!
Craiger
Old Aug 27, 2008 | 12:12 PM
blk92_d16's Avatar
^Good info! I was about to say that all of the window switch signals go through the master switch on the driver's side.
Yes, we don't know in your situation whether the pass. side switch works the window going down. Let us know... If it doesn't sounds like the master switches contact points have gone or a wire was pulled or something.
GL!
Old Aug 27, 2008 | 01:04 PM
v8 integra's Avatar
Default Re: (blk92_d16)
i have a 96 civic(ignore the s/n)..ive tried testing the switches with a test light only on the passenger side( and it came out good)..wat master module are u talking about on the driverside?? thanks for the info guys..
Old Aug 29, 2008 | 05:24 PM
v8 integra's Avatar
Default Re: (v8 integra)
Old Aug 30, 2008 | 09:36 AM
v8 integra's Avatar
anyone?
Old Aug 30, 2008 | 08:43 PM
v8 integra's Avatar
CALLING ALL MASTER MECHANICS!!!!!!!!!!!!!!
Old Aug 30, 2008 | 10:59 PM
v8 integra's Avatar
COME ON!!! PLEase!~
Old Aug 31, 2008 | 09:33 AM
v8 integra's Avatar
pleaseee i beegg!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!1
Old Aug 31, 2008 | 11:59 AM
gsxr1k05's Avatar
check continuity on the wires. maybe one is shorting out and thats why it works one way. also what about the window relay? could somehow half of it be bad? no one mentioned the relay, so i thought i would throw that up. and check the fuses while your there. just to say you did.
if the switches work in another car, you then know they are not defecive. same with the motor. wire it to another car and see if it works with your switches and their wires. if so, it would lead me to say its a harness problem.
Old Aug 31, 2008 | 04:53 PM
v8 integra's Avatar
Default Re: (gsxr1k05)
i took the motor out and connect it directly to the battery and the motor only haD juice going up and not down...so does that mean its the motor and not anythign else?
Old Aug 31, 2008 | 07:00 PM
monicle's Avatar
motor is bad
Old Sep 10, 2008 | 09:22 AM
craiger28's Avatar
Yes the motor/regulator is bad. I probably do this job on civic's/aacord's 20 times a year since I buy so many of them. Look on Ebay for the motor/regulator, make sure the part you buy if for both though. I have been buying them on ebay for years and they work great and you save big $ compared to an OEM one.
Old Sep 10, 2008 | 11:44 AM
v8 integra's Avatar
Default Re: (craiger28)
thanks alot dude!!! great info from everyone!
Dub C
Oct 8, 2010 05:49 PM
RGoose18
Aug 28, 2009 10:39 PM
damdash
Jun 24, 2009 05:08 PM
v8 integra
11
Oct 2, 2008 09:03 PM
viet_tec
Jul 20, 2007 11:49 AM
