civic rear disk conversion
Old Aug 25, 2008 | 11:04 AM
97blacklude's Avatar
Default civic rear disk conversion
hey i have all the parts i need. just wondering how everything comes off and gets put on.
Old Aug 25, 2008 | 11:11 AM
Hanmin's Avatar
there are 6 bolts holding the back discs off, 1 brake line thats a 10mm, use a flare wrench, and i think 2 brackets olding the cable up under the car, then theres a bracket thats holding the cable to the e brakes. Theres a writeup somewhere, all you gotta do is look for the bolts and undo em. And bleed your brakes when your done. oh yeah, you need a 4040 prop valve too.
here it is
https://honda-tech.com/zerothread?id=812062
Modified by Hanmin at 6:08 PM 8/25/2008
Old Aug 25, 2008 | 11:15 AM
EL Vap133's Avatar
Default Re: civic rear disk conversion (97blacklude)
Check here, all the info you need is here:
https://honda-tech.com/zerothread/1998336
Old Aug 25, 2008 | 12:26 PM
Allurian's Avatar
Default Re: (Hanmin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hanmin &raquo;</TD></TR><TR><TD CLASS="quote"> oh yeah, you need a 4040 prop valve too.
here it is
https://honda-tech.com/zerothread?id=812062</TD></TR></TABLE>
Everything is pretty much correct except for this. A 4040 prop valve is only needed if your are upgrading your front discs. Civic si eg's that came with rear discs use a 3030 prop valve stock not a 4040. Only if your are increasing the size of your front discs do you use a 4040 prop valve.
jdmem126
Feb 4, 2009 07:54 AM
Rob.
25
Nov 10, 2006 11:28 AM
Mashimaro
Jul 19, 2003 02:00 PM
brokeHonda
Apr 23, 2003 02:47 PM
marty
Dec 20, 2001 06:19 AM
