civic rear disk conversion
there are 6 bolts holding the back discs off, 1 brake line thats a 10mm, use a flare wrench, and i think 2 brackets olding the cable up under the car, then theres a bracket thats holding the cable to the e brakes. Theres a writeup somewhere, all you gotta do is look for the bolts and undo em. And bleed your brakes when your done. oh yeah, you need a 4040 prop valve too.
here it is
https://honda-tech.com/zerothread?id=812062
Modified by Hanmin at 6:08 PM 8/25/2008
here it is
Re: (Hanmin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hanmin »</TD></TR><TR><TD CLASS="quote"> oh yeah, you need a 4040 prop valve too.
here it is
https://honda-tech.com/zerothread?id=812062</TD></TR></TABLE>
Everything is pretty much correct except for this. A 4040 prop valve is only needed if your are upgrading your front discs. Civic si eg's that came with rear discs use a 3030 prop valve stock not a 4040. Only if your are increasing the size of your front discs do you use a 4040 prop valve.
here it is
jdmem126
02-04-2009 07:54 AM
Rob.
25
11-10-2006 11:28 AM
brokeHonda
04-23-2003 02:47 PM
