*****swapped b20vtec! extremely low idle!***** HELPPPPPP!!!!!!
Old Aug 25, 2008 | 07:59 AM
2.0 and up's Avatar
Default *****swapped b20vtec! extremely low idle!***** HELPPPPPP!!!!!!
I just recently did a complete b20vtec swap in my 97 ek hatch. I got a chip with a basemap from phearable.com for my p28 and everything seem ok until the car warmed up and that's when the idle dropped to roughly 200. The car starts but if I don't open the throttle the car boggs and completely shuts off!
Timing is on point(stock cams and injectors)
Msd dizzy is practically brand new
New tps sensor
Fuel is roughly about 40psi
The motor has 0 miles and all engine components are new! I tried messing w/ the idle screw in the tb(skunk2 70mm) but nothing happens, I turn and turn and still nothing. Also, if I take a plug from the intake manifold off and have a vaccum leak the car will idle at about 600 or so. That's the only way the idle will stay up so the car wouldn't shut off. Does anyone have any suggestions or ideas that might help? I am trying to break in my motor asap. Thanks in advance
-Xavier
Old Aug 25, 2008 | 08:08 AM
nytosc's Avatar
From: New York in the summer, South Carolina in the winter
Default Re: *****swapped b20vtec! extremely low idle!***** HELPPPPPP!!!!!! (2.0 and up)
IACV, FITV, coolant level, check mechanical throttle cable
Old Aug 25, 2008 | 08:10 AM
SinsEvil666's Avatar
Not sure exactly what would be the correct way to fix this....but last i cleaned my FITV....i closed it too much and my idle now is about 100-200 like u.....
I would take it out, clean it while ur at it and open it up just a bit to increase ur idle...thats what i have to do...
Old Aug 25, 2008 | 08:22 AM
2.0 and up's Avatar
Default Re: (SinsEvil666)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SinsEvil666 &raquo;</TD></TR><TR><TD CLASS="quote">Not sure exactly what would be the correct way to fix this....but last i cleaned my FITV....i closed it too much and my idle now is about 100-200 like u.....
I would take it out, clean it while ur at it and open it up just a bit to increase ur idle...thats what i have to do...</TD></TR></TABLE>
Yea thanks, I will try that! But the car sometimes barely turns on!
Old Aug 25, 2008 | 08:56 AM
Default Re: (2.0 and up)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2.0 and up &raquo;</TD></TR><TR><TD CLASS="quote">
Yea thanks, I will try that! But the car sometimes barely turns on!</TD></TR></TABLE>
haha, after normal temperature right? cuz mine does that...after i use it...turn it off...and try turn it back on...its struggles to turn on because of such low idle. but when cold....fires right up and at cold, idle is about 1400-1500
Old Aug 25, 2008 | 09:25 AM
TatDc5's Avatar
i had the same prob, it was my iacv... all i had to do was clean it with a q-tip and problem solved.
Old Aug 25, 2008 | 03:04 PM
2.0 and up's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SinsEvil666 &raquo;</TD></TR><TR><TD CLASS="quote">haha, after normal temperature right? cuz mine does that...after i use it...turn it off...and try turn it back on...its struggles to turn on because of such low idle. but when cold....fires right up and at cold, idle is about 1400-1500</TD></TR></TABLE>
Yea temp is normal. When it struggles to jump up it eventually starts and fires up to 6-700 than it rocks right back down to about 200 and eventually shuts off
Well today I installed new spark plugs, clean the iacv
Old Aug 25, 2008 | 03:38 PM
coupej1's Avatar
have you tryed to adj. the idle screw on the throttle body?
Old Aug 25, 2008 | 05:14 PM
2.0 and up's Avatar
Default Re: (coupej1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by coupej1 &raquo;</TD></TR><TR><TD CLASS="quote">have you tryed to adj. the idle screw on the throttle body?</TD></TR></TABLE>
Yea I tried and as I stated before, nothing happens...idk why but it turns an turns but thanks anyway
TEAM_PROGRESS
26
Dec 31, 2009 07:51 AM
ketchup
Feb 5, 2009 08:55 AM
FloridaCivic
18
Feb 24, 2007 12:23 PM
6thgen4u2nv
11
Jan 11, 2004 03:19 PM
