i can smell my coolant...
Old Aug 24, 2008 | 07:38 PM
EkFerio808's Avatar
Default i can smell my coolant...
okayy whenever like i drive short or long distance then when i park um turn off the car get out of the car i smell like my coolant or something and when i drive uphill it starts to boil soo whats wrong with it? i was thinking it was the the thermostat
Old Aug 24, 2008 | 08:39 PM
EkFerio808's Avatar
Default Re: i can smell my coolant... (EkFerio808)
bummmppp need help
Old Aug 24, 2008 | 09:09 PM
moz92's Avatar
you might have a leak somewhere. when i got on it i smelt coolant. i found out by looking under the car i and pin point where iys coming from. id let the car cool down and tthen looked to see where it was coming from. check your radiator hoses under the intake manifold hoses and heater hose. good luck
Old Aug 25, 2008 | 03:10 AM
BlackDeuceCoupe's Avatar
HT White Ops
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EkFerio808 &raquo;</TD></TR><TR><TD CLASS="quote">okayy whenever like i drive short or long distance then when i park um turn off the car get out of the car i smell like my coolant or something and when i drive uphill it starts to boil soo whats wrong with it? i was thinking it was the the thermostat </TD></TR></TABLE>
Probably got a rotted out cooling/heating system - radiator and heater core!
That would be my *guess*...
Old Aug 25, 2008 | 04:12 AM
alphalanos's Avatar
Default Re: i can smell my coolant... (BlackDeuceCoupe)
I had a hairline crack in my top radiator shroud. Run the car parked and rev it for a bit and have someone look tto see where its coming from.
Old Aug 25, 2008 | 05:04 AM
specoperformance's Avatar
you need to do a pressure test, if the cooling system wont hold pressure you know !00% there is a leak and while under pressure you can look for said leak
bopbop93030
Jan 31, 2008 12:05 AM
integranewb
May 7, 2007 02:12 PM
blumpfish
15
Jul 4, 2006 02:11 AM
DeDonDeRosa
Mar 21, 2006 10:37 AM
dustin
Jul 21, 2001 12:34 PM
