Fan won't turn on, never overheats, Fan will turn on with AC - help?
Old Aug 24, 2008 | 03:30 PM
Tr0LL's Avatar
Default Fan won't turn on, never overheats, Fan will turn on with AC - help?
My old radiator started leaking. I had to pour water in that thing every 3 days to keep it topped. However, temps never go pass the 1/2 way mark (it sits around 3/8's mark actually).
Just yesterday I replaced it with an aluminum radiator with stock fans. After refilling the coolant and bleeding with the radiator cap off, I noticed the fans never turn on. The car doesn't overheat or anything even with the car idling there for over 20 minutes. It stays at the 3/8's mark. The top of the radiator gets SUPER hot though (like I can't even touch it).
The fan relay in the fuse box looks fine. I even swapped it with the heater motor relay and still no fans. The fans DO turn on if I turn on the AC though so I'm guessing the fans work ok.
I did some searching, and what is this fan switch ppl keep saying to check? What else can I check? Even though it doesn't overheat, the radiator and the motor seem to get reeeeeeeeally hot where I can't even touch them.
Old Aug 24, 2008 | 03:48 PM
CompanyFlow's Avatar
Default Re: Fan won't turn on, never overheats, Fan will turn on with AC - help? (Tr0LL)
The temperature switch is probably faulty. It engages the fan after a certain temperature to prevent overheating. The fan will always go on with AC as logn as they are intact.
ScubaNole
Sep 12, 2019 08:37 AM
94_civicEx
Honda Civic (2001 - 2005)
Jul 20, 2010 03:32 PM
Oknoe.
May 6, 2010 03:43 PM
Arsenal
May 11, 2007 10:29 AM
