370 injectors to big for this setup?
Old Aug 24, 2008 | 03:10 PM
ncVTEC1313's Avatar
Default 370 injectors to big for this setup?
i have a chance to get some rc 370cc injectors, but i didnt know if it would be overkill on this setup, this is just the basic stuff that i see that would affect whether they would be to big or not.
gsr motor, standard bored/stroke
jg 64mm tb
skunk2 intake manifold
skunk2 valvetrain
skunk2 stage2 cams
jdm itr pistons
edlebrock header(will be upgraded to something better)
Old Aug 24, 2008 | 03:17 PM
CivSiClone_96's Avatar
Default Re: 370 injectors to big for this setup? (ncVTEC1313)
370 RCs should work perfect for that setup.
Old Aug 24, 2008 | 04:51 PM
JDMThoughts's Avatar
From: Standing on the corner selling cocaine, rippin shows live on stage for hoes yellin my name
Default Re: 370 injectors to big for this setup? (CivSiClone_96)
The following is guide for selecting fuel injectors corresponding to horsepower and stock fuel pressure (40psi at the fuel rail). The sizes were estimated using 90% duty cycle of the injector. The sizing of the injector is heavily dependant upon the air/fuel level the engine is tuned at (ex. 12:1 air/fuel will take more cc's than 12.5:1 air/fuel) :
310cc 200~220whp
370cc 220~280whp
440cc 280~330whp
550cc 330whp~380whp
660cc 380whp~425whp
720cc 425whp~475whp
880cc 475whp~525whp
980cc 525whp~600whp
Pulled this off evans-tuning.com I am not sure what power you make now, or what you plan to make.
Old Aug 24, 2008 | 06:34 PM
ncVTEC1313's Avatar
Default Re: 370 injectors to big for this setup? (JDMThoughts)
i think ill be lucky to make 200whp, i put down 176whp untuned with a stock worn out gsr bottom end. im sure my tuner can work the tune around them, so i think ill probably go ahead and get them
bosted429whp
May 21, 2016 04:22 PM
skunk2.com
Performance
May 14, 2013 01:45 PM
1990_integra_DA9
Jun 13, 2008 09:22 PM
TEGME
Mar 13, 2003 05:02 PM
