Performance General Performance oriented Parts (Ex: Camshafts, Electronics, Air Intakes, Exhausts, complete engines)
Skunk2 by Grams Performance Fuel Injectors
Old May 6, 2013 | 01:52 PM
skunk2.com's Avatar
Icon7 Skunk2 by Grams Performance Fuel Injectors
The new standard in high performance fuel injectors
Skunk2 is proud to team up with Grams Performance to produce the most innovative high-performance fuel injectors for today’s performance vehicles. Premium materials, advanced manufacturing techniques, and stringent quality control procedures make Skunk2 by Grams Performance the leader in high-performance fuel injectors.
An engine’s fuel injectors perform a vital role in the accurate metering and atomization of fuel. Skunk2 by Grams Performance accomplishes this with its high-impedance Bosch Motorsports EV14 fuel injectors that are modified for high-performance use. Each injector is individually balanced, flow tested, and dynamically matched for characterization within one percent of one another. To ensure leak-free operation and optimal performance, each injector is then pressure tested up to 220 psi. The results are unmatched cylinder-to-cylinder consistency, even at low pulse widths, as well as optimal idle quality, response, and performance. Grams Performance Fuel Injectors’ ultra-fast and precise solenoids feature a linear response curve across a wide range of operating conditions and can accurately meter fuel even at the highest pressures and shortest pulse widths.
The EV14 injector’s superior ball/pintle valves combined with Skunk2 by Grams Performance’s precision-modified nozzles allow for consistent performance up to 118 psi, making them suitable for a wide range of applications, yet without exhibiting any of the high-pressure problems often associated with other injectors. The optimized spray pattern also helps improve mixture preparation as well as atomization.
Skunk2 by Grams Performance injectors are cold-cut with diamond grinders in less than three seconds for high precision without “pre-seating.” Abrasive cutting creates heat, which leads to poor spray patterns and the need for competitors to pre-seat their injectors to reduce distortion. Each injector is also fitted with high-quality Viton O-rings that are resistant to extreme temperatures and harmful oils found in some fuels.
Each injector set includes dead time compensation values to help ensure consistent air/fuel ratios and optimal performance when tuning. Skunk2 by Grams Performance Fuel Injectors are carefully tested and matched in controlled laboratory environments using state-of-the-art equipment and are subjected to rigorous dyno, street, and race track testing to ensure proper performance in the most extreme conditions.
FEATURES:
• High-impedance design (no resistor box required)
• Cold-machined tips for high-precision operation
• Ultra-fast solenoids for precise fuel metering
• Linear response across wide range of operating conditions
• All injectors balanced, blueprinted, and matched within one percent
• Compatible with all known fuels including gasoline, methanol, and ethanol
• Unmatched cylinder-to-cylinder consistency and optimal idle quality
Visit the Skunk2 web store to see all applications and to buy.
Old May 14, 2013 | 01:45 PM
skunk2.com's Avatar
Default Re: Skunk2 by Grams Performance Fuel Injectors
ncVTEC1313
Aug 24, 2008 06:34 PM
85
Honda Motorcycles
Feb 13, 2007 08:30 AM
