Alternatives for d15b8
Hey I have a 94 eg hatch with the 8 valve d15 it has a blown head gasget. engine has 191,000 miles. Instead of having the head rebuilt i thought i would just replace the engine. what other SOHC engines are there that would drop right in and pass(california) smog.
D15B7 drops in no mods needed for the most part, D15Z1+D16Z6 swaps need a little wiring done for VTEC and 02 sensor etc. There are others, including JDM engines, but these would be the easiest.
Swap info is well documented and can be found here and elsewhere on the net.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96ex_white »</TD></TR><TR><TD CLASS="quote">so I would not have any problems with ECU or anything like that just a straight drop in with no problems for smog</TD></TR></TABLE>
Whatever engine you use you should get the corresponding ECU, or failing that chip your ECU to match.
MeanGreenEG9
Dec 24, 2002 06:43 AM
