Thought I had it fixed.
Old Aug 24, 2008 | 01:13 PM
Mike
Default Thought I had it fixed.
Thought I had my car fixed last week. Now a new problem.
My car can start without any gas going to the injectors. I have a cut off switch to my fuel pump. With the fuel pump switch turned off, my car starts, with it on, it wont turn over. Im getting spark either way so its a fuel delivery problem.
Now when I start the car and flip the switch on. It runs fine but smokes like Im burning coolant(white). This all happened yesterday for some reason. It had been running fine for about a week.
If anyone has had this problem lemme know whats going on. I am about to go and start tearing **** apart. Ill check back in like 30 mins or so.
Thanks HT!
EDIT MORE INFO:::
The last thing I did to it was readjust the FITV in because it was almost all the way unscrewed. That fixed the high idle problem. Now I look at the FITV alittle closer and noticed a leak from the side that connects to the engine. Could this be causing the problem?
Modified by Mike"IAMSLOW"Myers at 2:36 PM 8/24/2008
stlunatik806
May 3, 2010 01:35 PM
hoya_10fintec
Engine Management and Tuning
Apr 19, 2010 08:11 AM
msinsky14
Sep 8, 2006 07:13 AM
psychotic_z
Sep 20, 2004 06:21 PM
SoCal ITR
May 6, 2004 10:27 PM
