93 f22a1, with f22b motor
Old Aug 24, 2008 | 10:23 AM
LSTEG96's Avatar
Default 93 f22a1, with f22b motor
What problems am i going to encounter when trying to put the f22b into the 93? just wiring? are the timing belts the same?
Old Aug 24, 2008 | 02:26 PM
213374U's Avatar
0x5359-0055
Community Builder
Default Re: 93 f22a1, with f22b motor (LSTEG96)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSTEG96 &raquo;</TD></TR><TR><TD CLASS="quote">are the timing belts the same? </TD></TR></TABLE>
That last part threw me..... why should it matter? If you ever have the faintest opportunity to EASILY change your timing belt, you should. They're not expensive enough to pass up when it will save you from a 6 hour job down the road.
As for the swap, as long as you use everything associated with the F22B (axles, harness, ecu, etc.) you won't have a problem. A pull and drop job
Old Aug 25, 2008 | 11:59 AM
LSTEG96's Avatar
Default Re: 93 f22a1, with f22b motor (213374U)
i have nothing associated with the f22b except the longblock.
Old Aug 25, 2008 | 02:46 PM
likwid2u's Avatar
the f22b dohc? if so all h23 parts are the same
Old Aug 26, 2008 | 12:02 PM
LSTEG96's Avatar
Default Re: 93 f22a1, with f22b motor (likwid2u)
ok both motors are SOHCs.
93 honda accord body, stock f22a non vtec sohc in it right now.
i have a f22b vtec sohc waiting to go in. Are these two motors pretty much the same? If not what problems am i going to have trying to put this motor into this year accord
Old Aug 26, 2008 | 01:52 PM
213374U's Avatar
0x5359-0055
Community Builder
I believe there are 2 extra wires that you have to run. One for VTEC of course and the other I don't remember. You will have to get yourself a B1 ecu as well. This will vary depending on your tranny. MT or AT?
Old Aug 26, 2008 | 09:31 PM
LSTEG96's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 213374U &raquo;</TD></TR><TR><TD CLASS="quote">I believe there are 2 extra wires that you have to run. One for VTEC of course and the other I don't remember. You will have to get yourself a B1 ecu as well. This will vary depending on your tranny. MT or AT?</TD></TR></TABLE>
its a manual... are the timing belts the same by chance?
Old Aug 26, 2008 | 10:32 PM
bseriescrxsi's Avatar
i did thios swap last year i used the f22b motor(of course) f22a intake mani and the alternator pulleys are slightly off but can be changes quite easily...also the p/s lines are different and you will need to use the p/s assembly and pump from the f22a
Old Aug 27, 2008 | 06:56 PM
LSTEG96's Avatar
Default Re: 93 f22a1, with f22b motor (bseriescrxsi)
cool cool, what about the distributor? you say the intake manifold will bolt right up?
Old Aug 28, 2008 | 10:22 AM
the intake manifold took a little shaving to get around the vtec soldinoid and as for the distributor i used the one that came on the f22b and just fused the coil wires together(havent had trouble with it at all)...i mean i guess you can use the f22b intake mani but it would probably require alot more wiring
ak768
Nov 29, 2012 03:47 PM
BodyKits NW
Oct 9, 2001 06:50 PM
