Help with Wiring
Old Aug 24, 2008 | 06:05 AM
Nbboy7's Avatar
Default Help with Wiring
So my friend swap in a 97 dx motor in his 93 coupe. How do i wire in a 3 pin vac sensor to a 2pin engine harness
Old Aug 24, 2008 | 07:56 AM
Nbboy7's Avatar
neeed help
Old Aug 24, 2008 | 09:39 AM
Nbboy7's Avatar
Bump
Old Aug 24, 2008 | 10:47 AM
Speed_1's Avatar
are you trying to wire up the the wire IACV to a Three wire? i would suggest running a 2 wire IACV, assuming that you are using the whole D16Y7 intake setup, you'll need to change that out to a Different Intake manifold like his old one and then everything should just plug and play. If he tries to even run that POS Y7 intake in a 93 his car will idle like **** do to the fact that his stock PO6 ECU will not read a three wire IACV.
turbob18si
Dec 16, 2011 11:17 AM
SoFresh1189
10
Apr 6, 2010 06:46 AM
boricuacivic
Apr 6, 2009 09:02 AM
rc90hatch
Dec 22, 2005 06:03 PM
