timin belt a little tight, too tight?
I replaced my timing belt yesterday because I noticed excessive wear when checking under the hood. Turns out my tensioner froze up, so luckily I noticed it before the belt snapped. Anyway....I had recently swapped motors in my car from d15b7 to a d16z6, so I have the old motor. Well I took the tensioner from the d15 and put it on my z6. The d15 tensioner is a little bigger, but it works. The problem is it makes the timing belt kind of tight. What I want to know is if it will be ok being a little tight, or should I buy the z6 tensioner and change it ASAP? Its not whining or making any noise, nothing like that. So.....what do you think?
bryanja7
Sep 26, 2013 06:31 PM
