Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
Tire pressure
Old Aug 23, 2008 | 09:27 AM
grpape's Avatar
Default Tire pressure
I've been searching (with no success), looking for the right psi. to run in my tires on a 07' EXL V6 MT. Are the psi. ratings on the door correct? It seems to be a bit on the low side.
aloha, Derrick
Old Aug 23, 2008 | 10:43 AM
MSchu's Avatar
My Name is Nobody
Default Re: Tire pressure (grpape)
there is no such thing as correct settings... it's and adjustable feature and treated as such can be tuned to the type service you require
Old Aug 23, 2008 | 01:01 PM
BLKFLSH's Avatar
The tire pressure recommendation should be on the door jam. I always add 2lbs. so I don't have to add a pound each couple of weeks. I would rather have a couple lbs. over than under.
Old Aug 23, 2008 | 01:21 PM
grpape's Avatar
Gotcha! I'll fill up accordigly.
Old Aug 23, 2008 | 05:21 PM
cjo_28's Avatar
The door jamb sticker is Honda's recommended pressure. You can add a little extra pressure if you like, say, to increase MPG by a fraction or if you just like the ride better at 38 psi or whatever. Just don't exceed the maximum pressure rating that's on the tire (most passenger car tires are 44 psi).
Old Aug 24, 2008 | 01:56 PM
grpape's Avatar
Default Re: Tire pressure (cjo_28)
Yeah, Honda's reccomendation is way lower than what the tire max psi. is. I just found it weird to be that much off.
Old Aug 24, 2008 | 02:25 PM
nightfawl's Avatar
My tires sound pretty rough on the highway...Could that be because my tire pressure is too low?
Old Aug 24, 2008 | 03:07 PM
cjo_28's Avatar
Default Re: Tire pressure (nightfawl)
You're tires are probably choppy. It's hard to describe, but if you rub your hands around the tires, the tread will feel uneven/choppy. This causing road noise.
Old Aug 24, 2008 | 05:53 PM
nightfawl's Avatar
Is there anything I can do?
Old Aug 24, 2008 | 06:05 PM
cjo_28's Avatar
Not really. Once the tires are choppy, it's too late. It isn't a safety issue or anything. They're just noisy.
It's caused from a lack of rotation (and cheap tires are more prone to do it). With front wheel drive cars most of the weight is in the front, especially when braking (the weight shifts forward when braking). This causes the rear tires to wear funny. Rotate them at least every 7500 miles.
Well, rotate your NEXT set every 7500 miles
Old Aug 24, 2008 | 09:39 PM
grpape's Avatar
Is it just me, or do all new cars come with crap stockers. I don't rotate my tires, wanna wear them down faster to justify better shoes.
Old Aug 25, 2008 | 04:47 AM
MSchu's Avatar
My Name is Nobody
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by grpape &raquo;</TD></TR><TR><TD CLASS="quote">Is it just me, or do all new cars come with crap stockers. I don't rotate my tires, wanna wear them down faster to justify better shoes.</TD></TR></TABLE>
They always have, and they always probably will...
Old Aug 25, 2008 | 05:00 AM
nightfawl's Avatar
Well apparently these are brand new tires which I believe...They look brand new. They are Riken's which I don't think compare to Goodyear, Michelin or Yoko's. I actually thought maybe they were winter tires. The response I got from the dealer is that they are all seasons but they are M+S tires, which means they are more geared towards winter. Could that be why they sound so rough?
Old Aug 25, 2008 | 02:54 PM
jrzy2nR's Avatar
the psi on the door jam is correct
Old May 5, 2009 | 11:22 PM
ch0baca's Avatar
if you buy new tires, that are lower ratio and wider than stock's OEM, should you use the OEM tire pressure or lower/higher?
Old May 10, 2009 | 11:52 AM
BLKFLSH's Avatar
Originally Posted by grpape
Yeah, Honda's recommendation is way lower than what the tire max psi. is. I just found it weird to be that much off.
The pressure indicated on the tire sidewall is the MAXimum allowed pressure, not the "recommended" pressure. If these same tires were to be mounted on a heavier car, the "recommended" pressure for that car may be higher. I would not go over 35psi myself. The ride is rougher, and they would probably wear faster at 40psi.
Old May 14, 2009 | 10:24 AM
lilfotoman's Avatar
36-38 should be good.
benji7288
Nov 21, 2007 01:21 PM
Ash81
Sep 19, 2006 10:43 PM
phoshizzle88
Oct 14, 2005 06:53 PM
TealCivic93
Feb 19, 2005 05:04 AM
