Difinitive way to convert 5th gen rack to a TRUE manual rack?
Old Aug 23, 2008 | 09:26 AM
BB6-213's Avatar
Default Difinitive way to convert 5th gen rack to a TRUE manual rack?
I remember reading something a long time ago that someone removed a seal or o ring that enabled the 5th gen steering rack to function as a "true" manual rack, but I can't find any specifics on it, and since I have everything torn apart right now, I would like to knock that out if it is possible. Thanks guys.
Old Aug 23, 2008 | 09:47 AM
Hawkze_2.3's Avatar
Default Re: Difinitive way to convert 5th gen rack to a TRUE manual rack? (BB6-213)
Well, you want to make sure that the 'piston' that divides the 2 sides doesn't seal anymore. You can remove the seal or even drill holes in the piston...it's molded into number 15 here:
Then lube everything up with a good high-pressure grease very thoroughly.
I hope that's what you where talking about...
Old Aug 23, 2008 | 10:14 AM
BB6-213's Avatar
Hey thanks for your reply man, that looks like what I need so do. Now if I am to remover the seals which numbers do I remove, sorry, I really havent looked at the rack much.
Old Aug 23, 2008 | 11:58 AM
ethereal2pt2's Avatar
Default Re: (BB6-213)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BB6-213 &raquo;</TD></TR><TR><TD CLASS="quote">Hey thanks for your reply man, that looks like what I need so do. Now if I am to remover the seals which numbers do I remove, sorry, I really havent looked at the rack much.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hawkze_2.3 &raquo;</TD></TR><TR><TD CLASS="quote">You can remove the seal or even drill holes in the piston... it's molded into number 15 here.</TD></TR></TABLE>
Old Aug 23, 2008 | 12:24 PM
BB6-213's Avatar
Default Re: (ethereal2pt2)
Okay so #15 is actually the piston and the collar in the middle is the "seal" then right?
Old Aug 23, 2008 | 12:25 PM
BB6-213's Avatar
And pardon my ignorance, I have never looked much into the steering system.
Old Aug 23, 2008 | 12:27 PM
Hawkze_2.3's Avatar
Yep, the rings that are molded into the long shaft (#15...IDK what the name for it is ) should have a seal around them that you can remove....maybe they don't on a 5th gen, bit either way you just want to make sure that those rings do not seal anymore or produce friction within the rack so it's easier to turn the wheel.
Old Aug 23, 2008 | 12:29 PM
BB6-213's Avatar
Perfect!!!! Thanks so much. Out to the garage now.
Hawkze_2.3's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BB6-213 &raquo;</TD></TR><TR><TD CLASS="quote">Okay so #15 is actually the piston and the collar in the middle is the "seal" then right?</TD></TR></TABLE>
Yeah, collar is a better word for it rather than piston...the whole #15 piece is like the shaft that does all the steering, I don't know what you call it technically.
Old Sep 3, 2008 | 05:15 PM
BB6-213's Avatar
Hey guy's, so I looked at the Helm's and It says I have to puttl the steering wheel off and all this crap, and I was just wondering if there is an easier way to pull the rack out without having to go through that hassle?
jjspec
Dec 4, 2007 01:00 PM
lude98SH
Mar 28, 2007 06:44 PM
kornerk12
Feb 13, 2007 10:11 AM
kornerk12
Sep 6, 2006 09:22 PM
rexorz
Jul 31, 2003 01:23 PM
